585,560 active members*
3,136 visitors online*
    Sep 2007
    122
    Lightbulb Mazak 510C II Tool Unclamp Alarm 247
    Hello,
    I am continually getting a Tool Unclamp Alarm 247 on my Mazak 510C II. I can reset the ATC arm and we are monitoring the clamp and unclamp of the drawbar itself in manual mode and it seems to work great.
    I have run the Tool change in MDI mode and the same alarm will pop up.
    I have run the Tool change in MDI mode with-out tools in the spindle or "on-deck" pocket and the same alarm will pop up.
    It is intermittent and I am suspecting the hydraulic valve is going to puke.
    Any other thoughts? I will be pulling up the manual to determine if there is a drawbar finger / spring replacement I should be doing also.
    Thanks in advance.
    Sep 2012
    9
    Check air pressure. Check sensor unclamping tool.
    Sep 2007
    122
    I slowed the arm down with the Mitsubishi Drive software on the control (MRJ-2 Parameter 158). The 257 Tool Unclamp Sensor Malfunction and the 256 Tool Clamp sensor malfunction went away and now I am getting the 302 ATC arm Driver malf. and 303 ATC amr 0B malf. alarm. It looks like the arm is out of alignment just enough to touch the side of the spindle when it is changing the tool. We will start alignment procedure....
    Sep 2007
    122
    After further review, there is a remote oil reservoir that holds oil for the tool clamp/unclamp cylinder. This was low on oil.
    The picture is attached
Name:	Mazak tool change res.jpg
  1. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  2. mazak qt10 alarm 53 tool unclamp
    By joeld73 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-12-2017, 11:09 PM
  3. Renishaw tool change issue with Mazak 510c
    By Baader Kevin in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-08-2016, 05:09 AM
  4. mazak qt10 alarm 53 tool unclamp
    By joeld73 in forum Want To Buy...Need help!
    Last Post: 08-08-2012, 09:15 PM
  5. Mazak 510c renishaw ts27r tool setter help ?
    By buhlandy in forum Uncategorised MetalWorking Machines
    Last Post: 04-14-2012, 01:46 PM
