585,759 active members*
3,902 visitors online*
Page 1 of 2 12
Results 1 to 20 of 29
    Feb 2011
    210
    X3 Desktop CNC
    Finally I finished the whole design of the X3 desktop CNC I have planned for 12 months!
    The material is 6061 aluminum.
    Latest status:
    All the parts are being CNCed.
    Ordered all the standard parts including step motors, rails, bearings, drivers, power supplies, etc ...
    Very hopeful to have a nice machine being built here.
    Feb 2011
    210
    Cool Some raw material is in
    Just cut some raw material in the shop.
    Can you tell they coming together to be a CNC?
    Feb 2011
    210
    Start cutting the left and right gantry support parts.
    Feb 2011
    210
    First part done
    The gantry support looks great.
    Feb 2011
    210
    Table frame is in process now
    After a few test, things went very well. The gantry turned out beautiful.
    Table frame parts are being CNCed right now.
    Feb 2011
    210
    Adapter between control box and the CNC
    Received the PCB I designed for the CNC. All the wires go to this board first, then through a cable to the control box, which will be made out of a computer tower.
    Attached Thumbnails Attached Thumbnails adapter pcb1.jpg   1.JPG   2.JPG   adapter pcb2.jpg
    Feb 2011
    210
    Stunning
    Rendered in Solidworks.
    What is the software you are using for those 3D models? The renderings are awesome!
    "Experience is what you get when you didn't get what you wanted."
    Feb 2011
    210
    Quote Originally Posted by Pyronaught View Post
    Thanks. I am using Solidworks for mechanical design and Altium Designer for electronics. They are great tools.
    The motor holders are coming ...
    Really appreciate the 3D CAD tools. All the parts coming out of the CNC just fit perfectly, as I have designed on the computer.
    Do you do CAD work on Solid Works for a living? Those images look really pro, you've got every little detail modeled. Very nice.
    Feb 2011
    210
    Thanks for the comment.
    No. Mechanical design is my hobby. I do embedded system design, developing, and consulting.
    Feb 2011
    210
    Slow but more parts are coming.
    More parts got CNCed.
    Attached Thumbnails Attached Thumbnails 31aa6e804139d5ee97dc499576c648f9.jpg
    Apr 2009
    5516
    Nice parts! looking good...
    Feb 2011
    210
    Quote Originally Posted by louieatienza View Post
    Thank you. All the parts are pretty much done. Will start assembly after audit the critical dimensions.
    Sent from my iPhone using Tapatalk - now Free
    Feb 2011
    210
    All parts finished
    All the CNC parts have been inspected. Rails, Motors and driver arrived.
    The table is the most difficult part.
    The first attempt is 20mm alum with T slot. the part warped.
    Clamping was also the problem. At the end we glued the alum piece on the CNC table to get it flatness into spec. Also changed to threaded holes instead of T slot.
    Attached Thumbnails Attached Thumbnails 3cc3f33de4d3782e7028f0689831218b.jpg
    Feb 2011
    210
    Z Axis is done.
    Got busy, but I have all the parts now.
    Just taking time to put them together and fine tune them.
    Attached Thumbnails Attached Thumbnails z1.JPG   z2.JPG   0896bec6e09f3a95dd40d7e069782cb9.jpg
    Feb 2011
    210
    X, Y came together
    Oct 2013
    8
    Wow, that thing is built like a fortress! It looks great, can't wait to see some videos of it in operation eventually.
    Feb 2011
    210
    Attachment 204152
    Attachment 204154
    Very close to do some cutting ...
    Feb 2011
    210
    I will be working on the control box and all electronic over the long weekend.
    Next week will post the first cut video. I will video tape the very first try, bad or good, I will post it here, for the reason of how close it is between computer 3D modeling and the real life parts / assembly.
    I will use a slim computer tower for the control box. Skipped my stylish X3 control box design. Maybe X3 can do its own box :-D
Page 1 of 2 12
  1. desktop cnc UK
    By w i l l in forum Want To Buy...Need help!
    Last Post: 05-10-2009, 03:30 PM
  2. UK desktop CNC
    By colin from uk in forum Commercial CNC Wood Routers
    Last Post: 03-04-2009, 10:27 AM
  3. My Old Desktop CNC
    By CLaNZeR in forum European Club House
    Last Post: 06-20-2008, 05:12 PM
  4. desktop cnc UK
    By w i l l in forum MetalWork Discussion
    Last Post: 03-19-2008, 07:56 PM
  5. Desktop pc instead of plc
    By axis_control in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2008, 02:49 PM
