585,581 active members*
3,828 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Oliver intellicarve 1013 spindle problem
    Sep 2013
    I have a problem with the spindle of my Oliver intellicarve machine. It is 11 months old and was bought used with a known spindle problem. My issue is the best way to remedy the problem. I'm brand new to CNC, but have a back ground in woodworking and machine rebuilding.
    The spindle is press fitted onto the spindle motor and then the spinde slip fitted though a bearing to minimize lateral forces. Well, the spindle slipped down the spindle motor shaft and was galled by the bearing. I talked to Oliver and they recognized the issue and said the "new" one (mine is 11 months old) has a set screw to hold the spindle on and suggested I take it to a machine shop to pin or do it myself. Even then the spindle is galled. A new 150watt brushless motor with spindle is $240. Waiting to hear if they will sell me just the spindle.
    I proposed an exchange of the defective spindle motor/spindle for a new one. Two emails with pictures, serial numbers, and request have gone unanswered. I can start to understand I bought the machine used, but I would argue that the machine is not even a year old and fundamentally, the design was flawed, original owner or not.
    Am I being unreasonable? I can see the merits of a nonproprietary machine system.
    John
    24220
    I would have thought they would have offered some kind of recompense or partial cost in light if what seems like a design flaw?
    Al.
    Albert E.
    Sep 2013
    A big Thanks to Oliver for resolving the issue. I eventually connected with the service rep and received a replacement spindle motor at a reduced cost. I once asked a CNC owner how reliable his machine was and he response was that it was guaranteed to break! I can accept that answer, as long as there is some support behind the product. Thanks to CNCZone too.
  1. A Spindle Problem Found - A Spindle Problem Solved
    By oly2brf5 in forum Tormach Personal CNC Mill
    Last Post: 04-28-2013, 07:09 PM
  2. Oliver CNC Router
    By jweinhold in forum Want To Buy...Need help!
    Last Post: 06-29-2012, 04:29 PM
  3. Oliver Lathe
    By oldcherry in forum Wood Lathes / Mills
    Last Post: 02-14-2009, 08:03 AM
  4. HELP NEEDED FOR OLIVER 20B
    By oldcherry in forum RFQ Feedback
    Last Post: 01-19-2009, 01:27 AM
