585,760 active members*
3,833 visitors online*
    Jul 2013
    Sloping table on 3040t
    The table on my 3040t Chinese machine is about 1mm difference from tool to the table from one end of the y travel to the other end of the y travel. The table appears to be straight and level. Any advice on the best way of fixing this would be most welcome.
    Thanks glenn
    Mar 2013
    11
    1mm is a bunch -- can you shim under the where the table attaches to the frame??
    Les
  1. Has anyone added switches to a YooCNC 3040T control box?
    By DMcKee in forum Chinese Machines
    Last Post: 06-04-2018, 07:03 PM
  2. Play in leadscrew nut on 3040T router
    By nickjb in forum Chinese Machines
    Last Post: 05-01-2014, 05:25 AM
  3. Chinese CNC 3040T Slow Spindle Motor
    By Viking50 in forum Chinese Machines
    Last Post: 09-05-2013, 07:06 AM
  4. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 06:21 PM
