My VF4 10,000 rpm machine had the spindle motor / gear box replaced a while ago. The gearbox had gone bad and was making a lot of noise. The original motor was a baldor. The replacement is a 6 wire Lincoln. This is a older machine with a GPD503 drive. Ever since the motor was replaced the machine doesn't have as much HP as it use to. Of course the Tech that installed it said there was nothing wrong. I'm trying to diagnose it now and can not find a wiring schematic that shows the wiring at the spindle motor. I want to make sure the tech wired it correctly. This machine does not have the Wye / Delta option, thus no contactor between the drive and motor. Can't find anything about the motor via google. The motor is currently wired with T4-5-6 together and T1 to L1, T2 to L2 and T3 to L3. In looking at generic wiring diagrams, that looks like it is wired for Wye which also seems like the "start" wiring arrangement. Any Thoughts?
