585,991 active members*
6,343 visitors online*
    Apr 2013
    8
    +5v or ground
    hi everyone! newbie here, im sure one of you here has an idea of these connection,
    in this website :--> A simple breakout board <--
    in the "X8-6" connection, it says there +5V but in some design of schematic i saw,
    instead of "+5V" they use "ground" connection, im confused which is which?
    is there anybody can explain this?
    24221
    X8-1 to -6 requires +5vdc to turn the input on.
    Al.
    Albert E.
    Apr 2013
    8
    thank you very much al.
  1. New ground
    By cancnc in forum Mach Mill
    Last Post: 09-29-2013, 02:53 AM
  2. Frame ground vs. Electrical ground.
    By polaraligned in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-24-2008, 11:21 PM
  3. To Ground or not to Ground That is the question!
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 03-16-2008, 09:10 PM
  4. From The Ground Up
    By Crushmonkey in forum Open Source CNC Machine Designs
    Last Post: 09-30-2007, 03:53 AM
  5. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
