585,556 active members*
3,361 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > need sacrificial material to work with vacuum table
    May 2013
    5
    Question need sacrificial material to work with vacuum table
    I am looking for advice over what sacrificial material I can use on my newly acquired CNC router. I am cutting out acrylic parts and have built a vacuum table to assist in holding the material flat but I need a sacrificial material to protect the vacuum table and cutter whilst at the same time allowing air through in order to pull a vacuum against the underside of the work piece. I will cutting out various size parts from 5 - 8mm acrylic sheets 1200 x 1200.
    All help and ideas gratefully received.
    Apr 2005
    1268
    The material you want is LDF (Low Density Fiberboard) which is a lighter version of MDF! It goes by another name but I'm getting old and CRS has set in. Maybe someone will chime in and help. The big box stores most likely will not have it but the internet is your friend.
    Good Luck.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    How big is your pump? You can use regular MDF with a 10HP pump or bigger.
    May 2013
    5
    Hi Bill
    Thank you for your help. I wasn't familiar with the term LDF although it did stir a few of the remaining grey cells. On consulting the internet of images I can see it is what is commonly referred to over this side of the pond as 'chipboard'. Here is the thing though and please excuse my ignorance but Chipboard is full of glue so doesn't that prevent the air getting through it? I guess the thinner it is the more likely that it will work but I don't think I have ever seen chipboard here thinner than 1/2". Looks like I will be bashing the nearest proper wood yard to see what they can come up with.
    Thanks again.
    Ray
    May 2013
    5
    Hi Gerry. I am using an 850w 'Henry' style hoover. Don't know what that equates in horsepower but I am guessing it can't be much.
    So is MDF really porous?
    How thick is the piece you use?
    Do you have to machine off the smooth surface to make it so?
    Having a little trouble getting my head around air passing through that heavily compressed smooth surface.
    many thanks
    Ray
  1. durable vacuum table material
    By tcom-frazzled in forum Commercial CNC Wood Routers
    Last Post: 12-08-2020, 07:17 PM
  2. O-ring vacuum table to cut through material?
    By CaptainVee in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-08-2012, 01:30 PM
  3. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  4. Vacuum Table Spoilboard Material?
    By HobbyCAD in forum Chinese Machines
    Last Post: 06-22-2010, 02:51 PM
  5. Baseboard/vacuum table...are they sacrificial?
    By Matty Zee in forum DIY CNC Router Table Machines
    Last Post: 03-12-2007, 10:57 PM
