585,922 active members*
3,722 visitors online*
    Aug 2010
    7
    Exclamation Sodick EX21 CPU problem
    Hello!!
    I have a Sodick EX21 control with the CPU 02 stopped!! When the computer is loading the system and get the step 46 or 48 I got the message E016 CPU Stop.
    I've check the battery in both CPU and are OK
    Somebody know what could happend??
    Thanks.
    [email protected]
    Dec 2006
    131
    is all 3 LED's lit up on both CPU boards? Did you check the 5 volt power supply and make sure it's working and doesn't have any AC running on it?
    Aug 2010
    7
    Thanks.
    On the first CPU the leds are normal. The green is ON, the yellow is blinking fast and the second yellow is OFF On the second CPU the green is ON, the yellow is ON and the second yellow is OFF.
    Before the fail on the second CPU the second yellow was blinking slowly. When the system is loading the third yellow led (on the second CPU) is blinking fast as always, the problem is when the screen gets the 46 or 48 step the second led gets ON and stays like that. Then I get the message I mentioned on the screen.
    I've check the 5V PS and it's working.
    Thanks for your kind support.
    Aug 2007
    20
    Re: Sodick EX21 CPU problem
    how did you resolve this error?
    I have the same on my A535 MK25?
    Guy
  1. Needs help !!! Sodick A320D with AWT - Control EX21
    By mescotc in forum EDM Discussion General Topics
    Last Post: 08-22-2023, 06:44 PM
  2. SODICK A530D EX21 4-AXIS
    By systronic in forum Waterjet General Topics
    Last Post: 10-09-2019, 11:08 AM
  3. Sodick EX21 RS232
    By cncmedcom in forum EDM Discussion General Topics
    Last Post: 05-14-2014, 11:09 AM
  4. UG NX4 PostProcessor for Sodick EX21 A320D
    By Chris 1st in forum UG NX
    Last Post: 01-06-2009, 01:22 PM
