hi every one ineed to change fapt side language in english fanuc10tf control
it's a FAPT-side SYSTEM PARAMETER
My documentation is for Fanuc Series 16 FAPT but hopefully it is the same for Series 10....
0729
1: Japanese
2: English
3: German
4: French
5: Swedish
6: Finnish
7: Norwegian
8: Danish
9: Chinese
10: Dutch
11: Italian
12: Spanish
Optional ROM for specific language is required for Swedish language and beyond (i.e. 5 to 12)
If you do this please report back here if it works.
thanks for ur reply
it is not working 729 is un defined(un ussed)
many parameters are listed in the manual as 'undefined / unused'. that does not mean it is really unused. just try it in the machine.
the language numbers should be the same so if your language is set to (for example) Finnish look for a '6' in the SYSTEM PARAMETER table and change it to 2 then power the machine off/on. If the language does not change put that number back to where it was and continue searching through the parameters until you find another '6' then change that to 2. power off/on etc etc etc until you find it and fix the problem. if you cannot handle that contact Fanuc and pay them to fix it.
