586,009 active members*
4,744 visitors online*
    Mar 2010
    pressure for power chuck on cnc lathe
    how to calculate pressure for power chuck on lathe for different jobs?
    Feb 2009
    6028
    Do you mean clamp force of the chuck with a certain hydraulic pressure?
    You need to know the piston diameter of the actuator, the through bore size, and the type of chuck. Kitigawa has all the calculations for there stuff on line.
    Mar 2010
    Thank you underthetire. Hydraulic pressure adjustment is available on machine. Presently, for aluminium hollow castings we are using 3 bar clamping pressure and for steel 16 bar is used. Is there any quick calculation / chart available to decide the clamping pressure?
  1. Time to replace the power chuck on my CNC lathe?
    By Driftwood in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2012, 11:59 AM
  2. Chuck pressure on Mori NL2500
    By John 55 in forum Uncategorised MetalWorking Machines
    Last Post: 05-06-2012, 04:53 AM
  3. Chuck high low pressure
    By MCR-B II in forum Okuma
    Last Post: 07-23-2011, 07:22 PM
  4. Replies: 9
    Last Post: 04-05-2009, 05:42 AM
  5. How to use Power Lathe Chuck
    By John3 in forum Uncategorised MetalWorking Machines
    Last Post: 04-09-2007, 03:38 AM
