I'm using a desktop cnc machine to mill a material that is irregular in size and thickness that would be similar to potato chips made from wood or PVC (I can't divulge the material name due to business concerns). I mount 30 of these at a time, so there's no way to mount it with clamps or standard mounting materials. I run 3 different sets of G-Code they're pocketed, profiled and engraved.
I've tried carpet tape, double sided tape, standard spray adhesive (3M 77), as well as wood glue but they didn't work well.
I've found that using hot glue on the material and attaching it to a sheet of acrylic works pretty well to hold the pieces in place. I need them all to be the same thickness, but hot glue isn't always the same thickness, and I can't have too much variation (less than 0.1mm is all I have room for), so it works but not to the accuracy that I need.
I've considered a vacuum table, and I've been told that 3m makes a pressure sensitive spray adhesive, but it's fairly expensive to buy if I'm only going to use it once.
Are there any adhesives that would be similar to hot glue but consistent in thickness? Anyone have experience mounting odd shaped materials?
