Mach3, USB Key Board, CM-111
* Size : 93 x 36mm / Board : 1 pcs
* Keys : 20 Buttons + 11 Select Switches
* USB Cable A-B Cable 3M : 1 pcs
* Selector Switch : 4 Step / 2 pcs 3 Step / 1 pcs
* It can be applied main key of Mach3.
* If it is connected to USB in PC, it thinks it is a keyboard and no need to input power supply & driver.
* The MPG Button is linked with board in directly. It can modify botton's function.
You can get "User's Manual" below.
USB Keyboard, CM-111
