I have a Chevalier 2040VMC (2000 model year) with Anilam 6000M OS. When I end a program with an MO then a M5 for a spindle stop the spindle continues to rotate. At this point if you open the door the spindle slows to 50rpm but continues to run. if you select the spindle stop key on the console the spindle stops along with servos. I am guessing this may be a problem related to the drive.
I attached the program.
Thanks.. for any help
Mark
