585,997 active members*
5,108 visitors online*
    Oct 2013
    14
    Post 1250 lancer start up
    when the machine comes up and puch the power button the second time the drives some on and right back off i have checked the limit switches, over travel, and the sencers it will run as long as i hold the button it wat could it be
    Mar 2011
    463
    Do you have prints for the machine? Page 5 usually shows the bypass circuit that is causing your problem. I don't think I've ever run into anything but the limit switches causing it, but that page should show you all the possibilities.
    Oct 2013
    14
    yea i bypassed them and it still didn't change anything
    Mar 2011
    463
    What voltage do you have going into and out of each switch you jumpered? You could have a broken wire or a bad connection somewhere in the chain creating the same situation as if the switch was open.
  1. Cincinnati lancer 1250 power up
    By CMmetals in forum Cincinnati CNC
    Last Post: 10-09-2013, 03:35 AM
  2. Lancer 1250 Drawbar Solenoid Valve Sticking
    By LAIR82 in forum Cincinnati CNC
    Last Post: 08-08-2013, 08:29 PM
  3. Need CAD 3D and CNC Free Lancer!
    By betch23 in forum Want To Buy...Need help!
    Last Post: 01-17-2011, 07:26 PM
  4. Replies: 0
    Last Post: 03-30-2009, 03:55 PM
  5. Cincinnati Arrow 500 and Lancer 1250 Program Storage
    By Chaz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-10-2007, 03:10 PM
