586,005 active members*
5,086 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Jun 2011
    10
    Re: Mach3 ATC & Auto Tool Zero
    Hi
    i have fix the problem very easy issues working perfect.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    do not work with the macro MACRO IS WORKING PERFECT !!!!!!!!!!!!!!
    you need to fix tool offset !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  2. #22
    Jan 2015
    5
    Hello i have recently made a 1.1 mtre square cnc plasma table and i have put the probe tool set up code into machine but i ave the contacts for the zero probe on a micro switch the torch head is mounted on a sprung brkt witch moves torch towards micro switch as it gently touches material tub i need the probe to raise when it hits micro switch not lower into it ie the thickness of the touch plate ..any ideas i would really appreciate any help on this matter as i know it can be done but need the info to change the code to reverse the height instead of lowering on to work minus the touch plate regards Russ Beck
Page 2 of 2 12
  1. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  2. Problema con "Auto Tool Zero" en Mach3
    By lamartinada in forum Spanish
    Last Post: 11-23-2013, 11:51 AM
  3. Mach3 and Auto Tool Zero / Mach Blue Probing by Big-Tex
    By TomiY in forum Machines running Mach Software
    Last Post: 11-15-2012, 09:24 PM
  4. Ayuda con Auto Tool Zero en Mach3
    By hmoltedo in forum Spanish
    Last Post: 12-06-2011, 02:58 AM
