The capacitor used are usually AC motor run capacitors, so they are not generally open to shorting etc, however the start capacitor is usually a high value such as 100µf and is only rated momentary, if for some reason it is in circuit after the start it will overheat and blow.
The only thing I can think of is this is a start capacitor due to its large value?
Max.
Albert E.
