585,877 active members*
3,799 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Tool Library and tool paths.
    Aug 2012
    38
    Hi All,
    I have some indexable and custom ground tooling that never seems to cut right to size when modifying existing tools within the tool library. I was wondering if one can draw half the tool and save it to the tool library or import a DXF drawing of the tool into the tool library?
    (1) Is there a option to create helix tool paths on the XYZ axis to rough out pocket or to rough a circular interpolation? Basically I want to do is ramp helix to depth then helix from center out to the final diameter rather than plunging then stepping out to the final diameter.
    (2) Is there an option to rough plunge a part?
    (3) Can I perform a dwell drill cycle instead of standard peck drill cycle? I would like to drill to a certain depth pause for a second, drill deeper and dwell and so on as a chip breaker without a full retract.
    (4) We use Camworks inside of Solidworks, for simple jobs can I program within a DXF or 2D drawing inside Solidworks instead of programming from the solid model? A lot of the stuff we do is simple pockets and profiling, drilling and taping.
    Thanks In advance,
    Eric
    Mar 2008
    111
    Quote Originally Posted by EricMFG View Post
    Hi All,
    Check out TechDB7 defining and using custom tools in your pdf manuals.
    on your "feature Options" tab of the roughing OP change your entry method from plunge to spiral
    on the "roughing" tab select "Plunge rough" as your pattern
    depends on your post / controller
    you can, but it's better to use a solid model and easier! your just going back to the 2D cam bad old days of the 80's!
    Thanks In advance,
    Eric
    Get yourself booked on some training Eric, it will pay for itself!
    Dec 2012
    569
    Quote Originally Posted by jame5m28 View Post
    better yet, check out the camworks help files, which are excellent and would answer all of your questions. otherwise you will just find yourself lost again. you can give a man a fish.....
    most camworks windows will take you directly to a very relevant help page just by clicking on the button labeled "help"..seriously it works, and its context sensitive and useful
    Mar 2022
    13
    Re: Tool Library and tool paths.
    Knowledge4Sure offers you one-stop answer for all your Selling Aruba Products and Solutions test stresses. Don't bother packing extended notes or purchase costly instructional exercises. Knowledge4Sure's naturally planned HPE Sales Certified - Aruba Products and Solutions HPE2-W07 Exam Questions PDF give you the least demanding method for acquiring your objective HPE Sales Certified - Aruba Products and Solutions affirmation with the top score!
  1. SprutCAM Tool Library tool numbers
    By MichaelHenry in forum SprutCAM
    Last Post: 06-29-2016, 02:30 PM
  2. CNC Tool Library (Creation of ISO 30 Tool Holders)
    By ender_wiggen in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-27-2012, 08:59 AM
  3. Tool Library and Tool Menu ?s.
    By Stampede in forum BobCad-Cam
    Last Post: 01-16-2009, 01:56 AM
  4. 3d tool paths
    By ginamc in forum OneCNC
    Last Post: 03-19-2005, 06:17 PM
  5. Tool Paths
    By WOODKNACK in forum G-Code Programing
    Last Post: 04-27-2003, 02:09 AM
