584,866 active members*
4,937 visitors online*
    Mar 2011
    68
    Question Taper mill angle
    Hello,
    I am trying to personalize a little bit my post processor.
    I just want to add some names and infos to my tools and I have problem with a tool thread mill.
    I can not do my post to generate the tool angle I had tryed with angle and tool angle but everytime I have generated 0 degrees.
    Down you have what I wroted in post.
    if tool_type eq 9 then
    {'"FREZA_CONICA_D'tool_diameter:'5.3(p)','_LA_',to ol_angle:'5.3(p)','_GRADE"',' ---D'(tool_number), ')'}
    endif
    And it generate:
    N106 ( - T7-"FREZA_CONICA_D12_LA_0_GRADE" ---D7)
    I can mention that I write this line in @def_tool and I use a TAPED MILL with lover diam. 6.5mm and upper diam 12mm, with angle of 15degrees.
    Hope somebody can help me.
    Mar 2011
    24
    Is there a reason you do not put that information in the Part Tool Table? I would put the information in the “Description” FIELD or in Message field in the Tool Message TAB.
    NOTE: This will show up in the G code for this part only. If it is a “standard” tool edit your “global” tool table.
    Hope this helps
  1. Issue with G71 and Taper angle
    By dingo0722 in forum Okuma
    Last Post: 10-16-2019, 09:58 PM
  2. Taper angle on ER collet?
    By Jonne in forum MetalWork Discussion
    Last Post: 08-02-2012, 12:51 PM
  3. Difference in Female Taper angle using Taper Cutter
    By Buntron in forum Material Machining Solutions
    Last Post: 06-07-2011, 06:53 AM
  4. help with cutting a inverse taper angle
    By redfoxbody11 in forum Uncategorised MetalWorking Machines
    Last Post: 11-12-2010, 01:10 PM
  5. Fanuc servo shaft taper angle?
    By Jonne in forum Fanuc
    Last Post: 03-28-2008, 05:58 PM
