586,000 active members*
4,836 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Milling Gummy Aluminum....
Results 1 to 6 of 6
    Feb 2006
    7063
    I have to machine some aluminum extrusions (an off-the-shelf Hammond electronics enclosure) of an unknown alloy. But, it is the gummiest, most awful stuff I've ever seen! Even a slow plunge cut raises a huge burr all around the edge of the hole. I'm using a brand-new 1/8" HSS 2-flute, 6000 RPM, 0.010" DOC, 10 IPM feed, with flood coolant. The cut yields an awful surface finish, with a high burr the full length of both sides of the cut. Going slower doesn't help, and going faster, or deeper, just breaks the tool in short order. How does one machine this stuff?
    Regards,
    Ray L.
    lower the rpm , up your coolant concentration and don't plunge
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Mar 2009
    1863
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    It's probably dead soft material, and if it is, you'll never get a good finish and it will ALWAYS leave a big burr. Are you climb cutting or conventional cutting? Uf you're conventional cutting, you're nut really cutting material, you're just pushing it out of the way.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Feb 2006
    7063
    I did find out it's 6063, obviously not heat-treated. I've never seen anything so awful to work with. I tried using a larger (1/2") end mill to make a hole, then use the smaller endmill peripheral cutting to do the finishing. The 1/2" endmill hit the material, ramped down about 0.020", and was then summarily destroyed - corners broken off, all cutting edges completely mangled. You'd think I was trying to machine granite! I've thrown in the towel, and will take it to be either water-jet or laser cut....
    Regards,
    Ray L.
    15362
    SCzEngrgGroup
    Most extrusion is 6063, I have never had any troubles with machining it, I cut it quite a lot, Holes ,Slots, Threading Etc & use the same speeds & feeds as for 6061
    Mactec54
    Aug 2006
    143
    Micro 100 makes a single flute mill that I use to plunge cut extrusion. I can dig up the number tomorrow when I get to the shop if you want. I've put hundreds of holes in 6063 extrusion with them.
    Derek
  1. Drilling Alloy 20, 31% nickel, very gummy
    By Medmach in forum RFQ Feedback
    Last Post: 09-20-2013, 09:08 PM
  2. Milling aluminum dry
    By Mysta2 in forum MetalWork Discussion
    Last Post: 07-03-2012, 03:36 PM
  3. Gummy 6061 Aluminum Rod - Heat Treatment Options?
    By cjjonesarmory in forum MetalWork Discussion
    Last Post: 08-09-2010, 01:49 AM
  4. Aluminum milling job
    By zmaker in forum Employment Opportunity
    Last Post: 12-29-2009, 03:59 PM
  5. RFQ - Aluminum Milling
    By Axiom in forum Employment Opportunity
    Last Post: 03-06-2007, 05:29 AM
