586,009 active members*
4,818 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > SX2 milling machine enclosure ideas wanted
Results 1 to 12 of 12
    I have a SX2 mini mill bolted to my workbench, not cnc but i use it manually so still need to access all parts to operate. When using the machine the swarf goes everywhere, all over the bench and floor (and everything else in the shed) I am looking to build some sort of enclosure to keep all of the mess contained for an easy clear up at the end of the day. Im sure others with small sheds/workshops must have the same problem.
    Has anyone any ideas on the best way to go about designing/building such an enclosure? Was thinking of perspex or similar so i can still see what i am doing but not sure how to design it so as to still be able to use the machine freely?
    Any ideas welcome, thanks in advance
    Darren
    Aug 2004
    3215
    Quote Originally Posted by DarrenUK View Post
    Darren
    Here is a quick one I did.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Quote Originally Posted by joecnc2006 View Post
    Great job you did there, yes that's the sort of thing I had in mind but my issue is I use my machine manually. I am not sure what to do at the front so I am able to still operate the machine while keeping most of the mess inside the enclosure.
    Apr 2005
    419
    Generally for manual machines people set up barriers around the table. You can also get/make acrylic shields on magnetic bases that can be positioned around each cut.
    I don't think you will ever get it perfect with a manual machine.
    Quote Originally Posted by 691175002 View Post
    Thanks! Making something that fits around the table rather than the whole machine is a great idea that I hadn't thought of. That sounds more like it will fit my needs.
    Nov 2009
    4415
    What are you cutting? Is coolant involved? At 1 time as an experiment I stretched the leg of a pantyhose around the table and up over the spindle, oddly enough it worked well. No I do not live in SF, it was my wifes ;-) I have also used plastic bins with the bottom cut out to the size of the table, as mentioned above magnets work great.
    Quote Originally Posted by Fastest1 View Post
    No coolant, just cutting aluminium, usually just spray with WD40 as I cut.
    Nov 2009
    4415
    Try the panty hose idea. It will work great. Easy to access and who cares if you have to replace it.
    A lazy man does it twice.
    Mar 2010
    29
    I have an sx2 that I have converted to cnc. I just completed the enclosure. I built my enclosure right on top of my workbench. Now I can also run coolant as well as keep chips from going everywhere. The frame is made of 80/20 extruded aluminum and lexan. The lexan is sized to slide into the slot in the extrusion. I also used 80/20's corner connectors and slider addons. The corners make the box frame easy to build and the slider section is used to be able to slide doors open and closed. The doors are nothing more than lexan. The nice part of doors like this is that if you need to remove them you can do that without any tools in a sec.
    Feb 2008
    521
    something I collected elsewhere may help?
    Quote Originally Posted by kawazuki View Post
    Something similar to this I think would work for me, thanks for the picture.
    Nov 2009
    4415
    The local sheet metal company did this one for me. I had it powdercoated.
    http://www.cnczone.com/forums/dyna_m...0_refit-2.html
    I installed an 80/20 frame around the sides approx 20" tall or so.
  1. Computer Stand/Enclosure Ideas?
    By jet8300 in forum Computers / Desktops / Networking
    Last Post: 02-09-2019, 04:15 AM
  2. 4th Axis CNC Milling Machine wanted.
    By CharlesMartin in forum Want To Buy...Need help!
    Last Post: 10-14-2011, 06:06 AM
  3. My Novkaon NM 200 Enclosure, might give ideas to you guys as well....
    By g29cc in forum Tormach Personal CNC Mill
    Last Post: 08-14-2010, 04:12 PM
  4. Opinions wanted: Granite milling machine configuration.
    By Swiss in forum Linear and Rotary Motion
    Last Post: 05-27-2008, 01:41 PM
  5. Rockwell Vertical Milling machine parts wanted
    By 2_jammer in forum Uncategorised MetalWorking Machines
    Last Post: 03-20-2008, 07:33 PM
