585,933 active members*
3,597 visitors online*
Page 392 of 422 292342382390391392393394402
Results 7,821 to 7,840 of 8431
  1. #7821
    Nov 2017
    Hello , I've recently obtained my B.E degree in mechanical engineering and am now on a job hunt . I am browsing the web to join useful forums in order to gain some useful information.
  2. #7822
    Nov 2017
    27
    Re: Welcome thread-tell us about you.
    Hi, I am Antonis From Greece. I am working in a greek company that we produce heat exchangers.I am working cnc machines for over 17 years.At first I am here to found a post prossesor for Heidenhain tnc 426/430 working with Autodesk cam. Hello to everyone!
  3. #7823
    Nov 2017
    Hello. Came across this site all the time while researching.
    Been on the lookout for a decent and budget friendly machine for home use. Ended up ordering a screwdriven Workbee from Ooznest. Bought a Mitsubishi VFD and 0.8kW watercooled spindle to go with it.
  4. #7824
    Nov 2017
    6
    Pleasure to be here, my name is Yanny & i'm from NYC. I've always wanted to create things for myself or as small potential manufacture designs however always knew these types of machines were out of my reach at a young age. Recently I've come across Router machines and was impressed & intrigued at how possible it was to obtain such things now. I'm here for the learning & tinkering experience!
  5. #7825
    Nov 2017
    Hi All,
    I am glad to be here. I am a Mechanical engineering professional and an experienced CAD user/freelancer who have been absorbing information on cnc lately. Yesterday, I finally decided to build my cnc machine instead of buying one. The cnc I intend to build will be about 4 by 2 feet build, 4 axis and being able to cut soft metal. My budget is 1K and I am in the planning phase. I will be glad to receive guide in the right direction.
    Tajudeen
  6. #7826
    Nov 2017
    Hello to the community,
    Seeing that there are so many knowledgeable people in this forum, decided to become a member and ask some questions of mine.
    I'm just a IT tech and a CNC enthusiast seeking answers to questions.
  7. #7827
    Nov 2017
    7
    Hello!
    My name is Marshall and I live in the US. I am working on my second CNC machine (this one from scratch) and am running into a few questions! Hopefully, I will get some answers and eventually be able to provide answers to others sometime in the future.
    Thanks,
    Marshall
  8. #7828
    Nov 2017
    19
    Hello,
    My name is Brent. Mechanical Engineer. Went to Cornell. Love working on 80's CNC machines.
  9. #7829
    Nov 2017
    19
    Hello,
  10. #7830
    Nov 2017
    Hello I’m Roger. I am a Textiel technician and I am retired since 1 August. In my free time I’m making my first CNC Machine.
  11. #7831
    Nov 2017
    Hello, i'm DJAOUT. I'm a mechanical design engineer i'm in the design phase to make my prototype CNC plasma cutter.
  12. #7832
    Nov 2017
    Hello, to all. My name is Norman. I am a retired electrical engineer, and am interested in building, or buying a CNC router system.
  13. #7833
    Jul 2009
    12
    Hello: This is Tommy. I am located just outside of Austin TX. I have returned to finish what I started long ago before a series of family illnesses. Already received help from several members switching over to a USB based control board. Got it working in days. First 3 axis are running flawlessly at the moment. Rewiring my entire router right now; got sick of Molex connectors and my poor job of crimping - going to metal shell XLR and 12mm aviation style connectors. I want something robust and foolproof. Should be 100% in 3-4 weeks depending on shipping.
    With the new card it really seems like a heck of a lot more fun than last time. I built an extremely rigid 32 X 18 X 9 router out of heavy aluminum plate and extrusions. I am an electrical engineer, but still had to learn a heck of a lot to build this tool. All I need is cooling for the spindle and then I can mill the front panel for my controller. I really like the idea of using my mill to build hardware to finish my mill. Now I need to upgrade my 3D software and start building things for fun. Tommy
  14. #7834
    Nov 2017
    Hello:
    I am Ghassan Bitar,electrical engineer.
    I work in AMMAN JORDAN.
    My field is maintenance of electric machines.
  15. #7835
    Nov 2017
    Hello, my name is Denis, I'm in Wisconsin. I am a software developer.
  16. #7836
    Nov 2017
    4
    Hello, my name is Joshua. I work at a family owned and operated machine shop is South Jersey, right outside Philadelphia. I do mostly repair/maintenance machining and short run parts as well as some welding/fabrication and water-jetting.
  17. #7837
    Nov 2017
    Greetings All
    I'm retired from the DOD as one of the Exchange administrators for the Pacific Rim.
    I do woodworking and looking forward to making 2.5D reliefs, puzzles, and custom parts for gadgets I dream up.
    I've just finished the Openbuilds XL-C Beam. Never used one before and looking forward to the challenge. .
    Using PlanetCNC USB controller and software with Fusion 360.
  18. #7838
    Nov 2017
    Hello,My name is Aravinthan from Sri Lanka. I am a Mechanical Engineer. Interested in retrofit a lathe. Seeking help and advice from members.
  19. #7839
    Polentina Guest
    Hello,
    My name is Enrico, from Italy. Actually retired, but I was an EDM technician.
  20. #7840
    Polentina Guest
    Hi to all.
    My name is Enrico, from Italy. Actually retired, but I was a EDM technician.
  1. Thread spec for camera lens filter thread
    By cmays in forum MetalWork Discussion
    Last Post: 07-20-2016, 10:43 AM
  2. Thread Mill Wizard - Slanted thread produced
    By ngr1 in forum Mach Wizards, Macros, & Addons
    Last Post: 07-22-2012, 07:23 PM
  3. Special ID thread. sp-400 "M" type thread 8TPI
    By Captain Crunch in forum MetalWork Discussion
    Last Post: 04-05-2012, 09:39 AM
  4. acme thread combos and thread mixing
    By calaber40 in forum Linear and Rotary Motion
    Last Post: 05-16-2009, 02:04 AM
  5. Thread mill external NPT thread
    By cutting edge in forum MetalWork Discussion
    Last Post: 09-15-2008, 02:33 PM
