585,715 active members*
3,917 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Drilling home-made linear rails
    Apr 2007
    238
    I have made some "v-groove" linear guides out of 3/16" cold rolled steel which will be used with the v-grooved Bishop Wisecarver type bearings. I am preparing to drill holes along the rails so they can be mounted to the side of 80/20 aluminum extrusion. I have a drill press and a drill press vise.
    1. The rails will be held off the extrusion just a little with short standoffs so that the wheels can clear. How far apart would you recommend the holes/bolts be?
    2. I will be using a 1/4" bit and to get them aligned as accurately as possible, should I mark the holes with a center punch before drilling? Or what would you suggest?
    Thanks!
    Jun 2007
    3757
    Distance apart? Well that depends on how much weight the rail needs to support.
    Center punch, and drill a few sizes under, otherwise the 1/4" bit will almost surely cut oversize, even if it is new.
    Apr 2007
    238
    The rails are 3/16" thick x 1.5" wide, will be standing 'on edge' and will support about 35 lbs max.
    Jun 2007
    3757
    On their edge. Well 12" or so would be fine. It is the stability between mountings, in the 3/16" direction that is important for you.
  1. Home made table, with linear rails & ball screws
    By nateman_doo in forum Benchtop Machines
    Last Post: 05-09-2011, 04:37 AM
  2. comercial/home made screw for continuus linear motion?
    By fxs in forum Linear and Rotary Motion
    Last Post: 10-29-2009, 06:19 PM
  3. Home made linear bearings,
    By nobikes in forum Linear and Rotary Motion
    Last Post: 03-07-2009, 04:29 PM
  4. Linear Motors for a home made machine?
    By NEATman in forum Linear and Rotary Motion
    Last Post: 05-12-2006, 02:30 PM
  5. Bearings for home made linear
    By Alaskan in forum DIY CNC Router Table Machines
    Last Post: 08-14-2005, 07:09 PM
