I like Steeltailor products. Specially PowerII CNC cutting machine. The power can fit every country. PowerI can only fit for 180W. It is so good. The pre-heat oxygen is CNC controlled and very easy to operate.The introduction of guiding rail in the x-axis of the machine, enables a more stable movement of the crossbeam and avoids the cutting head from declining. The max cutting area:1.56M × 15.00M ( 5.12’ X 49.21’ ). So large . The maintenance can be done simply by removing the top cover to check up the controller.
Do you like it?
