There is the adjustment of Feed Rate in Mach Screen as below.
Here are two-bar graph.
Attachment 205596
The bar graph in left is Rapid FRO and the right is FRO %
Rapid FRO in left is G0 in the G-Code and it means that it adjusts the Feed when the Rapid not to start….
So, also the ratio, up to Maximum is 100%
If 100%, it is the speed value designated in velocity in Motor Tuning.
Whereas the FRO% in right adjusts linear transfer Feed such as G1, G2, G3 in G-Code.
Actually this is suppoed to lift up to 250% in Max. if the feed is low.
Feed graphs in left & right work together in default setting.
If you unchecked “Lock Rapid FRO to Feed FRO” in the Config – General Config,
two-feed can be adjusted separately.
You can know if adjusted the Feed while running G-Code in mach.
G0 X500
G0 X0
G1 X500 F1000
G1 X0 F1000
M47
Pls.. Refer to the file, save it first in your computer.
mach3_1024_all.set
