* PWM Signal to DC Voltage, Conversion Board. Speed Control of Spindle.
USD39.99 / 1 Unit, Free Shipping
PWM Signal is Converted into DC Voltage in Mach.
PWM Duty Cycle 0~100% Voltage selectable.
DC 0~10 V or 0~5V
Attachment 205764
* On Demanding Fine Adjusting.
1. Set Spindle Motor RPM to be hightest after finishing every set-up and measures the voltage in DCOUT.
If it is low, fits the voltage revolving variable resistance below picture.
Set the ideal voltage repeating the adjustment & the measurement not to change rapidly.
Attachment 205766
2. Set - Up in Mach is as follows. For setting the pin, use it is not used. (ex) Pin No. 8 was made.
Attachment 205768
3. Set it as follows.
Attachment 205770
4. To set maximun speed is as follows.
Attachment 205774
5. If so, can do speed control of spindle in Mach.
Attachment 205776
6. And if it is S1000 in G Code, it means that spindle RPM is 1000 If S5000, it menas that RPM is 5000
Attachment 205778
http://www.cnc4youstore.com/pwm-to-d...ree-ship..html
