585,567 active members*
3,528 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Need help roughing/milling.
    Sep 2013
    Hi, can't figure out how to mill this part out from the stock. It keeps milling on the side a little. If i try to change mill type and stuff edgecam does not mill the "pocket". It's a vertical cnc machine. I get it to work fine with a 8mm mill but not a 10mm which i want to use for stability and stuff.
    Thanks in advanced.
    Attachment 205928
    Attachment 205930
    The ppf file if anyone want to help me or give pointer.
    https://dl.dropboxusercontent.com/u/...7/millhelp.ppf
    Sep 2013
    Think i solved it with making boxes and using containment boundrary, atleast it looks alright in the simulation :P
    Aug 2013
    10
    Meybe the lead in/lead out moves are causing the problem, check it out. A proper toolpath should never engage into the model of the part...
    Have a great day - Adam
    http://www.reliefs3d.com/
  1. VCarve Pro - Roughing and Re-Roughing
    By louieatienza in forum Vectric
    Last Post: 01-20-2014, 05:20 AM
  2. Multiple Roughing Passes On 4 Axis Milling
    By ShortTrack in forum BobCad-Cam
    Last Post: 05-14-2013, 08:22 AM
  3. Milling questions, roughing end mill, size, etc?
    By Micro Milling in forum Benchtop Machines
    Last Post: 10-07-2012, 05:18 AM
  4. Advanced Roughing/Adaptive Roughing
    By jrmach in forum BobCad-Cam
    Last Post: 06-12-2012, 12:39 AM
  5. 3D Milling (Roughing & Finishing)
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-11-2009, 10:00 PM
