Code:
[POST_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V10.00 E1 P0 T1127411849 M10.00 I0
# Post Name : MPDX32
# Product : MILL
# Machine Name : BRIDGEPORT
# Control Name : DX32
# Description : BRIDGEPORT DX32 POST
# 4-axis/Axis subs. : NO
# 5-axis : NO
# Subprograms : NO
# Executable : MP 9.13
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
#| REVISION LOG: |
# Programmers Note:
# CNC 01/12/01 - Initial post update for V8.1
# CNC 05/22/01 - tlchng_aft was spelled incorrectly causing motion errors
# removed refht from pdrill_2.
# CNC 01/09/02 - Initial post update for V9.0
# CNC 08/12/02 - Added logic to ptlchg0 to address skipping outptu on null toolchange
# CNC 02/04/03 - Initial post update for V9.1
# CNC 05/28/03 - Initial post update for V9.1SP1
#| Features: |
# Following Misc_Reals & Misc_Integers are used:
# mi1 - Work coordinate system
# 0 = Reference return is generated and G92 with the
# X, Y and Z home positions at file head.
# 1 thru 3 = Reference return is generated and G92 with the
# X, Y and Z home positions at each tool.
# 4 thru 9 = The WCS of G54 thru G59 respectively at each tool.
# mi2 - Rigid Tapping enabled
# 1 = Rigid tapping mode enabled
# 0 = Rigid tapping mode disabled
# mi3 - Corner rounding
# 1 = Corner rounding enabled
# 0 = Corner rounding Disabled
# Options / Usage:
# It is recommended to start and end cutter compensation on a linear move.
#Canned text:
# Entering cantext on a contour point from within Mastercam allows the
# following functions to enable/disable.
# Cantext value:
# 1 = Stop = output the "M00" stop code
# 2 = Ostop = output the "M01" optional stop code
# END_HEADER$
# -------------------------- Format For Input Questions ---------------------
sprognum
srev
sname
fq 1 sprognum "Enter The Part Number"
fq 2 srev "Enter The Revision Number."
fq 3 sname "Enter The Programers Initials."
# Format Statements - i=incr., n=nonmodal, l=leave ldg., t=leave trlg.
fs 1 1.4
fs 2 1.4 #ld
fs 3 4 0
fs 4 2 0n
fs 5 3.1t
fs 6 3 0ln
fs 7 3 0n
fs 8 3.2
# Format Assignments
fmt X 1 x$ # X axis position
fmt Y 1 y$ # Y axis position
fmt Z 1 z$ # Z axis position
fmt I 2 i$ # Arc center in X axis
fmt J 2 j$ # Arc center in Y axis
fmt K 2 k$ # Arc center in Z axis
fmt N 7 n$ # Sequence number
fmt T 4 t$ # Tool number
fmt 4 tloffno$ # Tool diameter ofset number
fmt H 4 tlngno$ # Tool length offset number
fmt F 5 fr$ # Feedrate
fmt 5 plane$ # Modal plane code selector
fmt M 3 cc$ # Cutter Comp.
fmt S 3 ss$ # Spindle Speed
fmt 6 wcs # make Work Coord. string 'sgwcs' non-modal
fmt 6 drillcyc$ # make string 'sgdrlcyc' non-modal
fmt M 4 ssrange # Spindle Speed Range (mi2 - M42 = hi, M43 = low)
fmt M 4 sscode # Spindle Speed Code (M59 - M77 from tbl 1)
fmt 3 gcode$ # Format linear G-code selector for modality only
fmt Z 1 depth$
fmt Z 1 depth_out
fmt R 1 refht$
fmt Q 8 dwell$
fmt Z 1 initht$
fmt Q 1 peckincr1
fmt Z 1 peck1$
fmt Z 1 peck2$
fmt 4 dirchg$
fmt C 4 coolant$
fmt F 5 frplunge$
fmt 3 ccomp$ # Modal format for ccomp
fmt M 4 cantext$
# Formulas - Use ':' instead of '=' to initialize variables
skipmotest$ : 0 # Skip the motion test or xyz with previous xyz
plane$ : 0 # Initialize plane code to suppress first G17
spaces$ : 1 # Number of spaces to add between fields
seqmax$ : 99999 # Max. sequence number
omitseq$ : yes$ # Omit sequence numbers?
frrapid : 300 # Rapid feedrate? 300.0
frmax : 300 # Maximum feedrate? 300.0
ssmax : 3000 # Maximum spindle speed? 3000
breakarcs$ : 1 # Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
arctype$ : 1 # Arc center 1=abs, 2=inc, 3=st-cen, 4=unsigned inc.
do_full_arc$ : 0 # Allow full circle output? 0=no, 1=yes
helix_arc$ : 0 # Support helix arc output, 0=no, 1=all planes, 2=XY plane only
arccheck$ : 1 # Check for small arcs, convert to linear
ltol$ : 0.002 # Length tolerance for arccheck
tooltable$ : yes$ # Build next tool table
rigid : 0 # Rigid tapping performed
rigidon : 0 # Rigid Tapping enabled
nobrk$ : 0 # break rapid moves =0 Rapid as xyz=1, all moves broken=2
# Global Formulas
wcs = mi1$ # Work coord. system
#ssrange = mi2
sscode = frange(1,ss$) # Spindle speed code
cround = mi3$ # Corner rouding on/off 0=on, 1=off
# USE CANNED CYCLES?
usecandrill$ : yes$
usecanpeck$ : yes$
usecanchip$ : yes$
usecantap$ : yes$
usecanbore1$ : yes$
usecanbore2$ : yes$
usecanmisc1$ : no$
usecanmisc2$ : no$
# Bugs - used for post processor code customization
fastmode$ : yes$ # Enable Quick Post Processing, (set to no for debug)
bug1$ : 1 # 0=No display, 1=Generic list box, 2=Editor
bug2$ : 40 # Add postline label to each line at column 'bug2'
bug3$ : 1 # Add whatline to each line? yes/no
bug4$ : 1 # Add -.nci line no. to each line? yes/no
whatno$ : yes$ # Ignore whatline branches to plin1 etc.?
linktolvar$ : 1 #Associate X tolerance variables to V9- variable?
linkplnvar$ : 1 #Associate X plane specific variables to V9- variable?
linklvar$ : 1 #Associate X lathe specific variables to V9- variable?
newglobal$ : 1 #Enable error checking for global variables?
skp_lead_flgs$ : 1 # Do NOT use v9 style contour flags
get_1004$ : 1 # Find gcode 1004 with getnextop?
rpd_typ_v7$ : 1 # Use Version 7 style contour flags?
strtool_v7$ : 2 # Use Version 7 toolname?
cant_tlchng$ : 1 # Ignore cantext entry on move with tlchng_aft
tlchng_aft$ : 2 # Delay call to toolchange until move line
getnextop$ : 0
# Lookup table definitions - for Math Functions FLOOK and FRANGE
flktbl 1 12 # Lookup table no. No. of entry pairs
58 63 # Code 1 (output) Match 1
59 90 # Code 2 Match 2
63 112 # . .
64 180 # . .
65 224 # . .
66 355
67 450
73 710
74 900
75 1400
76 1800
77 2800
# Strings - String labels must start with 's' - they are not pre-assigned
sg00 G0 # Linear movement at rapid feedrate G code
sg01 G1 # Linear movement at feedrate G code
sg02 G2 # Circular interpolation CW G code
sg03 G3 # Circular interpolation CCW G code
sgcode # Target string for linear/circular motion G code
fstrsel sg00 gcode$ sgcode 4 -1# Select motion G code string
sm09 M09 # Coolant Off
sm08 M08 # Coolant Flood
smx8 M08 # Coolant Mist
smxx M08 # Coolant Tool
smcool # Coolant code target string
fstrsel sm09 coolant$ smcool 4 -1# Boolean handles modality
# coolant = 0 - coolant off
# coolant = 1 - FLOOD coolant on
# coolant = 2 - MIST coolant on
# coolant = 3 - TOOL coolant on
sm04 M04 # Spindle reverse - no coolant "M04"
sm05 M05 # Spindle off - no coolant "M05"
sm03 M03 # Spindle forward - no coolant "M03"
sm04c M04 # Spindle reverse - with coolant "M04"
sm05c M05 # Spindle off - with coolant "M05"
sm03c M03 # Spindle forward - with coolant "M03"
sm04cc M04 # Spindle reverse - with coolant "M04"
sm05cc M05 # Spindle off - with coolant "M05"
sm03cc M03 # Spindle forward - with coolant "M03"
spdlon # Target Spindle-on M-string
spdlsel = fsg2(coolant$) * 3 + fsg3(ss$) # Spindle on selector based on
# coolant - 0 = off, 1 = on
fstrsel sm04 spdlsel spdlon 9 -1
scc0 # cutter compensation state not changed
sg40 G40 # cancel cutter compensation
sg41 G41 # cutter compensation left
sg42 G42 # cutter compensation right
sg140 # Last linear move cancel cutter comp (see note)
# Note: to cancel comp after last move, remove G40 string
# with sg140 and remove "#" at the postline call "pcancelcc"
sccomp
fstrsel scc0 ccomp$ sccomp 5 -1
sg17 G17 # XY plane code
sg19 G19 # XZ plane code
sg18 G18 # YZ plane code
sgplane # Workplane G code
fstrsel sg17 plane$ sgplane 3 -1 # Select work plane G code
sg53 G53 # Work coordinate system G code #1
sg54 G54 # Work coordinate system G code #2
sg55 G55 # Work coordinate system G code #3
sg56 G56 # Work coordinate system G code #4
sg57 G57 # Work coordinate system G code #5
sg58 G58 # Work coordinate system G code #6
sg59 G59 # Work coordinate system G code #7
sgwcs # Work coordinate system G code
fstrsel sg53 wcs sgwcs 7 -1
sg81 G81 # drill - no dwell
sg82 G82 # drill - with dwell
sg83 G83 # peck drill - no dwell
sg83d G83 # peck drill - with dwell
sg73 G87 # chip break - no dwell
sg73d G87 # chip break - with dwell
sg84 G84 # tap
sg84d G84 # tap # must be here for selector to work
sg85 G85 # bore #1 - no dwell
sg89 G89 # bore #1 - with dwell
sg86 G86 # bore #2 - no dwell
sg86d G86 # bore #2 - with dwell
sgm1 GGG # misc #1 - no dwell
sgm1d GGG # misc #1 - with dwell
sgm2 GGG # misc #2 - no dwell
sgm2d GGG # misc #2 - with dwell
sgdrill # Target drill cycle G code
drlgsel = drillcyc$*2 + fsg2(dwell$) # 16 possible combinations:
# drillcyc = 0..7
# dwell = 0 or non-zero (2 states)
fstrsel sg81 drlgsel sgdrill 16 -1 # Drill cycle G string select
sgaccel G8 # Axis acceleration code
sgdecel G9 # Axis deceleration code
sgacc
fstrsel sgaccel dirchg$ sgacc 2 -1# Select accel/decel code with dir. chg. flag
# String select for corner rounding based off of mi3 value.
# used only when ccomp in is active.
sg48 G48 # Corner rounding off #0
sg49 G49 # Corner rounding on #1
sgcnrnd # Corner Rounding G code
fstrsel sg48 cround sgcnrnd 2 -1
#Cantext string definitions (spaces must be padded here)
sm00 "M00"
sm01 "M01"
strtextno
strcantext
strm M
sblank
# User-defined Postlines
pcool # Coolant on/off - init. off (coolant = 0)
if prv_coolant$ <> coolant$, n$, smcool
psg00 # Output "G00" via String Select Function to maintain modality
gcode$ = 0
*sgcode
!gcode$
pfr # Don't output neg. feedrate
if fr$ > 0, fr$
psccomp1 # Cutter comp on
n$, sccomp, *sgcnrnd, sgcode, prv_x$, prv_y$, pfr, pcan, e$
n$, sgcode, prv_x$, prv_y$, pfr, pcan, e$
psccomp # Cutter comp block used to repeat previous move for turning
# comp on. Comp does not take effect until two moves later due to
# the dx32's look ahead.
if ccomp$ = 2 | ccomp$ = 3, psccomp1
#Stuff i added
# Tool Table Function
tcnt : 0 # Count the number of tool changes-Used for Tool List
opcnt : 0 # Count the number of operations -Used for Tool List
fmt "TOOL" 18 tnote # Note format
fmt "DIA OFFSET D" 18 toffnote # Note format (use fs 1 0ln)
fmt " LEN OFFSET H" 18 tlngnote # Note format
fmt " DIA " 19 tldia$ # Note format (use fs 0.3t)
fmt 18 opcnt # Operation counter
pwrtt$ # Tool table at start of file
tnote = t$
toffnote = tloffno$
tlngnote = tlngno$
opcnt = tcnt + 1 # operation counter = tool counter +1
if t$ >= 0,
";", *tnote, pstrtool, "", e$
tcnt = tcnt + 1
# Tool Comment / Manual Entry Section
ptoolcomment #Comment for tool
if omitseq$ = 1, pbld, *n$, e$
tnote = t$
toffnote = tloffno$
tlngnote = tlngno$
";", *tnote, pstrtool, *tldia$, " ", e$
pstrtool #Comment for tool
if strtool$ <> sblank,
strtool$ = ucase(strtool$)
*strtool$, " "
pcomment$ #Comment from manual entry (must call pcomment2 if booleans)
pcomment2,e$
pcomment2 #Comment from manual entry
scomm$ = ucase (scomm$)
if gcode$ = 1007, " ", scomm$, " "
else, " ", scomm$, " "
# Postline - (pre-assigned)
pupstring # Strings to upper case
sprognum = ucase (sprognum)
srev = ucase (srev)
sname = ucase (sname)
if sname = sblank & qexit = yes$,
result = mprint(susername)
exitpost$ # Stops post execution
pheader$ # File header
17,e$
";", e$
";Program ", sprogname$,".TXT",e$
if tooltable$ = 1,
"; ", e$
";START OF TOOL LIST", e$
psof0$ # Start of file for tool zero 1001
psof$
psof$ # Start of file for non-zero tool number 1001
";START OF PROGRAM", e$
n$, " ",e$
n$, "G75", "G90",e$
n$, " ",e$
ptoolcomment
n$, t$, "M06",e$
pcan
pcan1, n$, ss$, "M03", strcantext,e$
pcan2, n$, psg00, *x$, *y$, e$
n$, psg00, *z$,e$
rigidon = mi2$
ptlchg0$ # Null tool change 1000
#if prv_z <> zr, n, *sg00, zr ---Use tlchng_aft in V8
rigidon = mi2$
if gcode$ = 1, plin$
else, prapid$
ptlchg$ # Tool change 1002
n$, " ", e$
ptoolcomment
n$, *t$, "M6",e$
n$, *ss$,"M03",e$ #JEvans
pcan
pcan1, n$, psg00, *x$,*y$, strcantext,e$
pcan2
n$, psg00, *z$,e$
rigidon = mi2$
prv_fr$ = -1
peof0$ # End of file for tool zero 1003
peof$
peof$ # End of file for non-zero tool 1003
n$, "G00",e$
n$, xh$, yh$,e$
n$, "M22",e$
4,e$
20,e$
prapid$ # Linear line movement - at rapid feedrate 0
pcan
pcan1, n$, psccomp, *sgcode, x$, y$, z$, pfr, strcantext,e$
pcan2
pzrapid$ # Linear movement in Z axis only - at rapid feedrate 0
pcan
pcan1, n$, psccomp, *sgcode, *z$, pfr, strcantext,e$
pcan2
pylin # Linear movement - y motion test
pcan
pcan1, n$, psccomp, sgcode, *x$, *y$, pfr, strcantext
pcan2
plin$ # Linear line movement - at feedrate 1
pcan
psccomp
pcan1, n$, sccomp, sgcode, *x$, *y$, z$, pfr, strcantext,e$
pcan2
pz$ # Linear movement in Z axis only - at feedrate 1
n$, sgcode, z$, pfr,e$
pcirp2 # Circular interpolation 2
psccomp
pcan1, n$, sgplane, sccomp, *sgcode, *x$, y$, *z$, *i$, *k$, pfr,
strcantext
pcirp1 # Circular interpolation 2
psccomp
pcan1, n$, sgplane, sccomp, *sgcode, x$, *y$, *z$, *j$, *k$, pfr,
strcantext
pcirp0 # Circular interpolation 2
psccomp
pcan1, n$, sgplane, sccomp, *sgcode, *x$, *y$, z$, *i$, *j$, pfr,
strcantext
pcir$ # Circular interpolation 2
pcan
if plane$ = 0, pcirp0,e$
if plane$ = 1, pcirp1,e$
if plane$ = 2, pcirp2,e$
pcan2
pdrill0$
depth$ = abs(depth$)
pdrill$ # Canned Drill Cycle
if dwell$ <> 0,
n$, *sgdrill, "G04", *x$, *y$, *depth$, *dwell$, *frplunge$,e$
else,
n$, *sgdrill, *x$, *y$, *depth$, *frplunge$,e$
ppeck$ # Canned Peck Drill Cycle
n$, *sgdrill, *x$, *y$, *depth$, *peck1$, *peck2$, *frplunge$,e$ #JEvans
pchpbrk$ # Canned Chip Break Cycle
ptap$ # Canned Tap Cycle
if rigidon = 1, n$, "G95", "M29",e$ #JEvans
if rigidon = 1, rigid = 1
pbore1$ # Canned Bore #1 Cycle
pdrill$ #JEvans
pbore2$ # Canned Bore #2 Cycle
pdrill$ #JEvans
pmisc1$ # Canned Misc #1 Cycle
pmisc2$ # Canned Misc #2 Cycle
pdrill_2$ # Canned Drill Cycle
n$, x$, y$, depth$,e$
ppeck_2$ # Canned Peck Drill Cycle
pdrill_2$
pchpbrk_2$ # Canned Chip Break Cycle
pdrill_2$
ptap_2$ # Canned Tap Cycle
pdrill_2$
pbore1_2$ # Canned Bore #1 Cycle
pdrill_2$
pbore2_2$ # Canned Bore #2 Cycle
pdrill_2$
pmisc1_2$ # Canned Misc #1 Cycle
pdrill_2$
pmisc2_2$ # Canned Misc #2 Cycle
pdrill_2$
pcanceldc$ # Cancel canned drill cycle
if rigid = 0, n$, "G80",e$
else, n$, "G80", "G94", "M28",e$
rigid = 0
pcancelcc$ # Cancel cutter comp.
n$, "G40",e$
pwrtt$ # Tool table line format
# Canned Text
pcan #Canned text - before output call
strcantext = sblank
if cant_no$ > 0,
if cant_pos1$ = 0, pcant_1
if cant_pos2$ = 0, pcant_2
if cant_pos3$ = 0, pcant_3
if cant_pos4$ = 0, pcant_4
if cant_pos5$ = 0, pcant_5
if cant_pos6$ = 0, pcant_6
if cant_pos7$ = 0, pcant_7
if cant_pos8$ = 0, pcant_8
if cant_pos9$ = 0, pcant_9
if cant_pos10$ = 0, pcant_10
n$, strcantext, e$
strcantext = sblank
pcan1 #Canned text - with move
strcantext = sblank
if cant_no$ > 0,
if cant_pos1$ = 1, pcant_1
if cant_pos2$ = 1, pcant_2
if cant_pos3$ = 1, pcant_3
if cant_pos4$ = 1, pcant_4
if cant_pos5$ = 1, pcant_5
if cant_pos6$ = 1, pcant_6
if cant_pos7$ = 1, pcant_7
if cant_pos8$ = 1, pcant_8
if cant_pos9$ = 1, pcant_9
if cant_pos10$ = 1, pcant_10
if cstop$, strcantext = strcantext + sm00
if cgstop$, strcantext = strcantext + sm01
#Output of strcantext occurs at the end of the output line
pcan2 #Canned text - after output call
strcantext = sblank
if cant_no$ > 0,
if cant_pos1$ = 2, pcant_1
if cant_pos2$ = 2, pcant_2
if cant_pos3$ = 2, pcant_3
if cant_pos4$ = 2, pcant_4
if cant_pos5$ = 2, pcant_5
if cant_pos6$ = 2, pcant_6
if cant_pos7$ = 2, pcant_7
if cant_pos8$ = 2, pcant_8
if cant_pos9$ = 2, pcant_9
if cant_pos10$ = 2, pcant_10
n$, strcantext, e$
strcantext = sblank
pcant_1 #Canned text - output call
cantext$ = cant_val1$
pcant_out
pcant_2 #Canned text - output call
cantext$ = cant_val2$
pcant_out
pcant_3 #Canned text - output call
cantext$ = cant_val3$
pcant_out
pcant_4 #Canned text - output call
cantext$ = cant_val4$
pcant_out
pcant_5 #Canned text - output call
cantext$ = cant_val5$
pcant_out
pcant_6 #Canned text - output call
cantext$ = cant_val6$
pcant_out
pcant_7 #Canned text - output call
cantext$ = cant_val7$
pcant_out
pcant_8 #Canned text - output call
cantext$ = cant_val8$
pcant_out
pcant_9 #Canned text - output call
cantext$ = cant_val9$
pcant_out
pcant_10 #Canned text - output call
cantext$ = cant_val10$
pcant_out
pcant_out #Canned text - build the string for output
#Assign string select type outputs
#Build the cantext string
if cantext$ = 1, strcantext = strcantext + sm00
if cantext$ = 2, strcantext = strcantext + sm01
if cantext$ > 2,
strtextno = no2str(cantext$)
strcantext = strcantext + strm + strtextno
# Numbered questions for Mastercam Mill
38. Rapid feedrate? 300.0
1538. Rapid feedrate (metric)? 10000.0
80. Communications port number for receive and transmit (1 or 2) ? 2
81. Baud rate (110, 150, 300, 600, 1200, 2400, 4800, 9600)? 4800
82. Parity (E/O/N)? N
83. Data bits (7 or 8)? 8
84. Stop bits (1 or 2)? 1
85. Strip line feeds? N
86. Delay after end of line (seconds)? 0.0
87. Ascii, Eia, or Binary (A/E/B)? A
88. Echo keyboard to screen in terminal emulation? N
89. Strip carriage returns? N
90. Drive and subdirectory for NC files?
91. Name of executable post processor? MP
92. Name of reverse post processor? RP
93. Reverse post PST file name?
100. Number of places BEFORE the decimal point for sequence numbers? 3
101. Number of places AFTER the decimal point for sequence numbers? 0
103. Maximum spindle speed? 5000
107. Average time for tool change (seconds)? 2.0
159. Show first and last position as fully compensated in simulation? n
161. Enable Home Position button? y
162. Enable Reference Point button? n
163. Enable Misc. Values button? y
164. Enable Rotary Axis button? n
165. Enable Tool Plane button? n
166. Enable Construction Plane button? n
167. Enable Tool Display button? y
168. Check tplane during automatic work origin creation? n
# Default Miscellaneous Real Values
201. Default Index start angle? 0.0
202. Default Index incremental angle? 0.0
203. Default miscellaneous real variable 3 (mr3)? 0.0
204. Default miscellaneous real variable 4 (mr4)? 0.0
205. Default miscellaneous real variable 5 (mr5)? 0.0
206. Default miscellaneous real variable 6 (mr6)? 0.0
207. Default miscellaneous real variable 7 (mr7)? 0.0
208. Default miscellaneous real variable 8 (mr8)? 0.0
209. Default miscellaneous real variable 9 (mr9)? 0.0
210. Default miscellaneous real variable 10 (mr10)? 0.0
# Default Miscellaneous Real Values (METRIC)
1601. Default miscellaneous real variable 1 (mr1) (metric)? 0.0
1602. Default miscellaneous real variable 2 (mr2) (metric)? 0.0
1603. Default miscellaneous real variable 3 (mr3) (metric)? 0.0
1604. Default miscellaneous real variable 4 (mr4) (metric)? 0.0
1605. Default miscellaneous real variable 5 (mr5) (metric)? 0.0
1606. Default miscellaneous real variable 6 (mr6) (metric)? 0.0
1607. Default miscellaneous real variable 7 (mr7) (metric)? 0.0
1608. Default miscellaneous real variable 8 (mr8) (metric)? 0.0
1609. Default miscellaneous real variable 9 (mr9) (metric)? 0.0
1610. Default miscellaneous real variable 10 (mr10) (metric)? 0.0
# Enable/Disable Miscellaneous Real Variable switches
1611. Enable miscellaneous real variable 1? y
1612. Enable miscellaneous real variable 2? y
1613. Enable miscellaneous real variable 3? y
1614. Enable miscellaneous real variable 4? y
1615. Enable miscellaneous real variable 5? y
1616. Enable miscellaneous real variable 6? y
1617. Enable miscellaneous real variable 7? y
1618. Enable miscellaneous real variable 8? y
1619. Enable miscellaneous real variable 9? y
1620. Enable miscellaneous real variable 10? y
# Default Miscellaneous Integer Values
301. Default Work Coordinate System (0=G53,1=G54 to 6=G59)? 1
302. Rigid Tapping mode enabled (1=Yes, 0=No)? 0
303. Default Corner Rounding On (0=off, 1=on)? 1
304. Default miscellaneous integer variable 4 (mi4)? 0
305. Default miscellaneous integer variable 5 (mi5)? 0
306. Default miscellaneous integer variable 6 (mi6)? 0
307. Default miscellaneous integer variable 7 (mi7)? 0
308. Default miscellaneous integer variable 8 (mi8)? 0
309. Default miscellaneous integer variable 9 (mi9)? 0
310. Default miscellaneous integer variable 10 (mi10)? 0
# Enable/Disable Miscellaneous Integer Variable switches
1621. Enable miscellaneous integer variable 1? y
1622. Enable miscellaneous integer variable 2? y
1623. Enable miscellaneous integer variable 3? y
1624. Enable miscellaneous integer variable 4? y
1625. Enable miscellaneous integer variable 5? y
1626. Enable miscellaneous integer variable 6? y
1627. Enable miscellaneous integer variable 7? y
1628. Enable miscellaneous integer variable 8? y
1629. Enable miscellaneous integer variable 9? y
1630. Enable miscellaneous integer variable 10? y
# Configuration File association parameters (default is "y")
#400. Name of associated cfg file?
401. Read SYSTEM COLORS section? y
402. Read ALLOCATIONS section? y
403. Read TOLERANCES section? y
404. Read DATA PATHS section? y
405. Read COMMUNICATIONS section? y
406. Read DRAFT SETTINGS section? y
407. Read MISCELLANEOUS section? y
408. Read NC SETTINGS section? y
409. Read DIALOG SCRIPTS section? y
410. Read DESIGN SETTINGS section? y
411. Read PLOTTER SETTINGS section? y
412. Read ALT-KEY ASSIGNMENTS section? y
413. Read CAD section? y
414. Read START/EXIT section? y
415. Read SCREEN section? y
416. Read FILE NAMES section? y
1500. Chook to execute from 'Misc. values' button?
1501. Insert parameter information in the ascii NCI? n
1502. Write operation information to binary file (.ops)? n
1503. Write transform operations (0=transform ops, 1=source ops, 2=both)? 1
1520. Display a warning when cutter compensation in control simulation finds an error? n
1521. Number of controller look-ahead blocks for CDC in control? 2
1530. Ignore work offset numbers when processing subprograms? y
1531. Ignore contour flags when processing subprograms? y
# Do NOT manually change the answer for Q.1999 !
1999. Product major version number that post supports? 9
3001. Machine acceleration? 2
3002. timing size? .1
[CTRL_MILL|DEFAULT]
[misc integers]
1. //1
3. //1
[CTRL_MILL|MPDX32]
[misc integers]
1. //1
3. //1
[CTRL_TEXT_END]
