So there I was, cutting this piece over and over again (ironically, to save money) by setting my G54 further and further toward the spindle... After I was satisfied I had the program running perfectly, I went away for a few days. When I came back, raring to get on with production work, I put a fresh piece of material in the lathe, commanded the CHNC 1 to go, and the X axis crashed big time. The X axis tried to face way too much, wrenching the material (alum) from the step chuck, and tossing it into the back wall. Needless to say, I learned a BIG lesson.
Well, nothing really bad appeared to happen - after some sullen reflection, I adjusted my offsets, put another piece in the chuck, and started producing parts - in fact, I did this for two days - part after part after part... about two dozen post-crash parts in all.
Today, I finally got some more time to make some fine adjustments, so I started up and homed the CHNC 1. But when I ran my program the X-axis lerched in spurts, then failed with a "DAC-limit reached." A soft reset wouldn't work, nor did simply restarting the control. The machine had to be powered off completely before it could recover. I re-homed the machine and again, the X-axis stuttered before failing and displaying the "DAC-limit reached" error.
I decided to go into the X-axis cover to looking for a stretched belt. After poking around and not seeing anything obviously wrong (e.g. really loose or messed up belt), I tried again. However, over the coarse of my investigation, the X axis actually got worse and now can't even be homed. The instant I hit either X button to home, the machine throws a fault. Even with the feed rate set to 10%.
I'm stuck. I took the tiny ball-screw access panels off both X and Z and turned each with a 3/16 allen key - the Z axis is a bit smoother. The X is clunky, as if it's stopping on detents. I can't imagine the ball-screw is bent from a crash, but could the drive have stretched throwing all the tuning off kilter? Could the X-axis motor have become decoupled by a safeguard clutch?
I started poking around in the back, looking for lit LEDs that might divulge a particular error, but the only one is a red LED on the drive board in the upper left corner of the right-side electrical cabinet. I also noticed a buzzing coming from the amplifier board immediately to its right (and not from the identical one immediately to ITS right, the Z-axis drive), but may have been doing this before and I just never noticed.
So now, the control error is of no help. The only error I get is the "AXIS DRIVE FAULT" error, and a red LED on the board itself. The errors won't clear unless I completely cycle the power, and return the instant I even breathe on the X job buttons or turn the ball-screw manually with the allen key.
I must turn to the experts of the CNC Zone in the hope someone here has encountered something similar before.
I have photographs of LEDs, boards, and can produce a wealth of other information if it should prove helpful.
This leads me to ask a couple of questions:
1) Could a crash loosen a belt such that it causes the control to throw an error? (e.g. too much lag)
2) Could poking at the belt exacerbate #1 such that it gets worse?
3) Could it be a coincidence, and the crash did nothing (after all, I machined a dozen parts afterward.)
4) Is anyone familiar with the alarm codes in the back of all this hardware?
5) Can anyone offer advice of any kind?
6) ANYONE KNOW Ex-Hardinge Techs who can help me fix this (for $$$?)
Ugh. A year of using this machine without problems, and now that I'm ready to go into full production, I crash and now this happens.
Thanks, Murphy.
Torin...
www.walker-tech.com
