585,708 active members*
3,601 visitors online*
    Nov 2011
    Boye Laser Spin 1006
    Hi
    I am trying to setup an old Chinese Laser - it has been sitting in a box for 5 years, I got it working. Can anyone advice what type of file does it read ?
    I emailed the supplier but no response... It does have a USB reader, so if I can only figure what format to send the file in will help.
    Thanks in advance
    Nishan
    Jun 2013
    45
    Hi Nishan
    Looking at this website, Boye laser I found the below specs for a V-SPIN-1006. Don't know if this is the same model as yours but it may be similar.
    Does the laser machine have any software with it at all?
    Have a look at the electronics and tell us what controller it has. This will indicate what software would be needed.
    Relevant Parameters
    Laser Power: 50W/60
    Wlaser Type: CO2 sealed laser tube,water-cooled,10.6 um
    Work Size: 850*570
    Cutting Speed: 25-40000mm/min
    Laser Energy Control: real-timeadjustable
    image Recognition Range: 105mm*80mm
    Graphics Format Support: DST、PLT、BMP、DXF
    Software Support: TAJIMA、CORELDRAW、PHOTOSHOP、AUTOCAD、all type of AUTOCAD software in cloth
    Compatible Software: Cut settings organized by color
    Dimensions: 1520*1030*1015
    Total power: 1000W
    Nov 2011
    I have visited this website and even called them, but language is a barrier. I have sent all those formats to the machine but it does not read any of them. Basically I need a software called laserca.exe .... which reads these formats and then saves it into the format reqd by this machine. ( I think )
    Thanks for the help. Will keep u posted.
    Dec 2006
    124
    Provide a photograph of the control card that is located in your laser machine. Often times, there is more than one software that will work on the control card. For example, the Leetro and Googal cards can run the LaserCut software.
  1. fanuc drillmate / robo drill alarm 1006 clamp
    By goodplastics in forum Fanuc
    Last Post: 07-30-2015, 12:19 PM
  2. fanuc o-t alarm 1006 tool position error
    By Korellibopper in forum Fanuc
    Last Post: 11-18-2011, 06:48 PM
  3. Can a Grizzly 1006 be CNC'ed?
    By madtownrob in forum Benchtop Machines
    Last Post: 08-04-2010, 07:26 PM
  4. Alarm 1006 on hardinge lathe
    By TARIQ08 in forum Hardinge Lathes
    Last Post: 09-10-2008, 01:33 PM
  5. Fanuc O-m Alarm 1006
    By CNCEDMDUDE in forum Fanuc
    Last Post: 09-01-2006, 02:13 AM
