585,974 active members*
4,219 visitors online*
    Aug 2011
    7
    Mazak VCN 530C vs Mazak VCS 530C
    Hello,
    I am looking to purchase my first Mazak vertical machine for production machining of aluminum castings. I have previously only used Haas machines. I am trying to decide between the VCN 530C (Nexus control) or the VCS 530C (Smart control). The VCN costs about $10,000 more than the VCS.
    Do you feel that it would be worthwhile to pay the extra for the Nexus control? Or is the Smart control good enough?
    Other than the controller, are there any major differences in the machine construction between the two models?
    P.S. If I am posting this in the wrong forum feel free to move it.
    Oct 2013
    62
    We have both machines in the shop...
    It depend if you are machining a variety of part or a single one over the whole life of the machine.
    If you answered a single part you should go with the VCS and save money.
    Otherwise go with the VCN and avoid headaches with program transfer, memory capacity (we even have to split program in 4 or 5 smaller ones to get it loaded on the NC of the machine.)
    Both machines deliver the same accuracy and output per our experience.
  1. Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    By Mill&Lathe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2022, 01:55 AM
  2. Mazak QT-10 T2 manuals --acct w/ mazak?
    By CDTINC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-21-2012, 05:09 AM
  3. Mazak 6pc with machine Mazak 400n
    By anva in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-17-2010, 08:30 AM
  4. Mazak
    By dario0305 in forum CNC Machining Centers
    Last Post: 05-14-2010, 09:34 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
