585,728 active members*
4,759 visitors online*
    Oct 2010
    266
    Small Delrin bushings
    Looking to have these little bushings made from Delrin. Initial batch I'm looking for around 100-200 for testing and then 1000+ after that
    Including a picture which isn't that good but it's a simple piece. Approximately 5.5mm length, 6mm outer diameter and inner hole diameter is 4.1mm. In the middle is a rounded portion that is 6.6mm in diameter so basically a 6.6mm circle dissecting the cylinder
    Please email to [email protected]
    Wanting someone who could work on these in the next few days and have a decent turn around time
    Oct 2010
    266
    Attached a PDF of the part with dimensions for quoting. Final dimensions may possible change but would only be by a few tenths of a mm at most.
    Oct 2010
    266
    any other offers let me know. will be proceeding with these in the next day or two
    Nov 2013
    6
    Is this RFQ still open?
    Jan 2006
    73
    Please PM me if you still need these parts made.
  1. Replies: 13
    Last Post: 09-10-2007, 07:00 PM
  2. Delrin vrs Bronze bushings
    By BoxGods in forum Linear and Rotary Motion
    Last Post: 03-01-2007, 06:51 AM
