585,759 active members*
4,129 visitors online*
Results 1 to 9 of 9
    Oct 2013
    34
    Fanuc OT or 18-series
    Hello.
    Can anybody tell me which one that is the oldest. Is it Fanuc OT series or Fanuc 18-series (msc-518) ?
    Aug 2007
    793
    AFAIK, in case of systems without "i" index
    0TA, 0TB are older than 18T
    0TC - a contemporary
    0TD is a contemporary or newer
    Apr 2009
    1379
    The 0A,0B and 0C were designed in the late 80s. The 0D came in the early 90s, same as the 16A/18A. The 16/18B and 16/18C came after.
    Oct 2013
    34
    Thank you for the help
    Feb 2009
    6028
    MSC-518 (mori designation) came after the 0 ( Mft-4 mori designation)
    Dec 2013
    Can anybody tell me if there is a way to adjust the screen brightness on these? (MSC-518)
    It has the new LCD instead of the old CRT monitor and it looks like the backlight is still functioning, so I'm curious if there is a Parameter or knob I'm missing.
    Its on a Mori SL-300
    Aug 2011
    2517
    On my machine (MSG-500) there's a PMC parameter (not a standard Fanuc parameter)
    normally it should not be necessary to play with the brightness.
    it sounds like you have some kind of LCD issue but you dont say what?
    Feb 2009
    6028
    If it has the black an white LCD, the contrast adjustment is in the settings, second page down I believe.
    Sent from my G-Tab Quantum using Tapatalk
    Dec 2013
    Thanks. I'll take a look.
    The issue is that some of our operators are old and can't see the screen very well. I can see and read it just fine.
    However I do suspect that lcd backlight might be going bad.
  1. Fanuc Series 18T
    By M.RISHIKESH in forum Fanuc
    Last Post: 07-31-2013, 01:36 PM
  2. Fanuc 0M Series
    Last Post: 04-08-2013, 03:05 AM
  3. help with fanuc i series
    By joshuac in forum DNC Problems and Solutions
    Last Post: 06-04-2010, 08:35 AM
  4. GE FANUC SERIES 15M
    By rajesh_1355 in forum Fanuc
    Last Post: 06-10-2008, 11:59 PM
  5. Fanuc on a Series 2
    By HillBilly in forum Bridgeport / Hardinge Mills
    Last Post: 01-07-2006, 07:50 PM
