okay i actually am not sure this would work..but i think it might..and if it did it could be really useful for anyone who wants to know precise spindle output power and torque, but their machine doesnt have any provision for it.
this should measure torque accurately even if no rpm signal is available. add the rpm signal and you get power too.
so i was looking at my mill and i thought of this. i am sure im not inventing something new, but i havent seen anyone make one of these, so its new to me.
the way my spindle is setup, its a motor, which drives a pulley, which goes to another pulley with a belt. the second pulley is directly connected to the spindle shaft.
i noticed the motor is mounted with two bolts. one appears to be spring loaded so that its not clamped so it wont move, but its held tightly with the two disc springs. the other bolt does clamp down tightly with no springs. so if you loosen the "clamp" bolt, you can pivot on the spring loaded bolt, and in this way, adjust belt tension.
so it occured to me that if you left the "clamp" bolt loose, the motor housing would want to rotate in equal torque and opposite direction to the applied torque!
my particular motor has a little 3" arm screwed into its housing on the same side as the clamp bolt, to grab when you are adjusting belt tension. i think if i turned the spindle on and held onto that arm, id have to put equal torque on it as the spindle was applying torque. so if i replaced me with a luggage scale from that arm to somewhere, i could measure force and compute torque!
now after a little more thinking, i think that since the pivot point is the other side of the housing and not the axis of the motor, it wouldnt actually work. so to make this actually work, id have to make some kind of plate which allowed the motor to freely rotate about its axis, but maintain belt tension (distance between pulleys).
ill have to think about exactly how this plate would work, but i think its a simple idea and shouldnt be hard to work out.
just because you are freeing up the rotation of the motor housing doesnt mean it will actually move. you can use a strain gage or load cell or luggage scale (which uses a strain gage) and it will all be "solid"..if you use a spring of some kind, it will move though.
so does this make sense?
the reason i call it universal is that pretty much any motor could have its output torque measured using this method. and since most of us can machine a simple plate, i would think alot of people could make their own adapter and rig up a very accurate spindle power/torque meter!
so now ill try to think of how the plate would need to be designed.
-must allow motor axis to spindle axis distance to be adjusted and locked in place (no freedom) for belt tension
-must allow motor housing axis rotation freedom (for torque measurement). no actual rotation is really needed, just freedom of rotation. (i suppose even with a strain gage there is some actual rotation, but its on the order of tenths of thousands)
heres my mill, which im sure is similar to many other mills. the tallest black box is the motor. the pulleys and belts are behind the grate with the zillion little holes in it. the spindle is also pictured
