Hi, I mounted the coupling on the ballscrew and motor and as you can notice in the videos, there is some noise from coupling not (maybe) being properly mounted on both ends but it is quite difficult for me to mount it without stretching the spirals of coupling.
Do you have any idea/trick for doing this?
Also, does the coupling needs to be sliding easily to the ballscrew and motor shafts? I needed to hit with a elastic-head hammer in order to insert the motor shaft into the coupling and then screwed the bolts of coupling to each shaft respectively.
??????0002 - YouTube
??????0000 - YouTube
Thanks.
