I have another wiring issue that I need to make sure that I am wiring correctly, the vacuum pump. I have enclosed pictures of the terminals and wiring diagram under the lid of the box.
Attachment 207114
Attachment 207116
Attachment 207118
From what I understand, the top terminals are 3 legs as the vacuum pump is 220v 3 phase. on the opposite side two terminals have wires leading to the capacitor 1brown one blue.
If I am correct, what I need to do in order to connect my 220v wire and plug, is connect black(hot) to open terminal on the bottom right. Connect white(hot) to the terminal just to the left of the empty one (the one with the blue wire already attached). Then green to ground. Is this correct?
