Hi all-
Looks like the gremlins are back.
I finally have my MD3 up and running enough that I am starting to use it. So I ordered several new tool holders, new end mills, a 1/2 drill chuck.
UPS dropped off the box, and I decided to play on the mill. That is where the problems start.
So far I have replaced the VFD, I have replaced the suppressor board, and the CRT, and a few other small things.
So here is what happened today.
When I turn the mill on, the display turns on and goes through the self check. Everything is ok.
Press manual, then the power button. (I can hear the motor contactor pull in- Loud Chunk) same as always
then I press the start button. Nothing - There is usually another softer clunk. But nothing.
I can not calibrate the axis, turn on the servo, or move any axis.
I have checked and I have the AIR connected and the pressure is about 100 PSI.
How can I check to make sure the controller is seeing the air pressure?
Where should I start looking next?
Steve
