585,877 active members*
3,351 visitors online*
    Dec 2006
    310
    Blue Dump Windowx Xp
    Dear Sirs
    We have got NoteBook Model HP Mini 210-1000, Bios Revision F.24, Processor type Intel® Atom(TM) CPU N450 @ 1.66GHz
    V get blue dump
    When we try to install Xp, then all the files keep getting copied then when Window set up starts, again Blue Dump appears
    a) We have fitted this Haddisk in another PC, getting recognised, formatted this in the same, Format is OK ie Harddisk is OK
    b) Also run quickheal antivirus
    c) Taken out battery and fitted back
    Please advice
    Regards
    MSRJV
    Sep 2008
    117
    The first thing I would do would be to test the memory.
    Gene
    Apr 2006
    3206
    I would upgrade to Windows 8.1
    All your problems will be over.
    I agree with checking the memory.
    Apr 2009
    5516
    You can set the BIOS if it isn't already to do a memory test.
    There might be a component in your laptop that doesn't like one of the device drivers Windows is trying to install. You can look at the dump file and usually it's the last entry that is causing the problem, like nvinst.dll or something like that. You might be able to start up in safe mode, just hold F8 after the BIOS screen. If you can do this then you should be able to use process-of-elimination to figure out which device is causing errors, and disable it until you find a current driver online.
    I would try Win7 32 bit if you can't get XP to go. If it did have XP to begin with you can usually get the oroginal drivers that came with the laptop by going to the website and either searching the model number or entering a service or serial number.
  1. Blue Screen mostly black instead of blue
    By turmite in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-01-2013, 10:27 PM
  2. OIL DUMP!
    By bigfoot in forum Uncategorised MetalWorking Machines
    Last Post: 02-04-2010, 05:19 PM
  3. how to dump offsets?
    By teamjnz in forum Fanuc
    Last Post: 02-24-2009, 06:03 PM
  4. Dump circuit?
    By jdholbrook in forum Hobbycnc (Products)
    Last Post: 07-06-2006, 06:09 PM
