585,743 active members*
4,887 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V25 : 4 axis wrapping for text on a cylinder
Results 1 to 12 of 12
    Mar 2012
    1570
    This video shows you the steps to put text on a cylinder using your 4th axis.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Jan 2011
    73
    Please Al Depoalo if I'm doing a new rotary index, for my lathe, could I use the file created by AutoCAD with the same circumference as the new knob, as a new stock on V25, reporting numbers and the division instead of the text as You used on this example?
    Thanks for helping!
    Mar 2012
    1570
    I am not sure what you are asking... Are asking if you can use the milling tool path on a lathe with live tooling?
    Al DePoalo
    Jan 2011
    73
    Wrapping
    Hi....
    I need to make a new knob as a rotary index on my lathe. So You used a raw of text to engrave on a cylinder...I have to use a specific number of line on the knob, one over each 9 degrees, and the relative figure starting from zero to 19 corresponding at one decimal movement of my new screw. The question is if I use instead of Your text raw my file, as attached here, does it will works?
    Attached Files Attached Files
    Mar 2012
    1570
    sure you can use any text or geometry for wrapping. These tool path is posted for a mill. So if you are running this on a lathe, it would depend on your controller. Some controllers will convert milling tool path to live tooling ( haas has a g code for this ).
    So yes, you can create a dial knob using wrapping tool path with your mill.
    Al DePoalo
    Jan 2011
    73
    Thanks for Your help! I'll use my own mill for doing it!
    Best regards
    Mar 2012
    1570
    Here is screen shot using your text...
    Al DePoalo
    Jan 2011
    73
    A new question
    I did my definitive knob, You can found it as attached file, and during the simulation, I have standard V25+4th axe, I see my part rotating offset from the centre as an half diameter. It is because I posed my zero on top of the cylinder or because of this is a limitation of my version of BobCad..... Thanks for processing my question...
    Mar 2012
    1570
    I think the only problem that you have is you machine loaded is a 3 axis mill and not a 4 axis mill. Once you load a 4 axis mill you shouldn't have any issues.
    Al DePoalo
    Jan 2011
    73
    ..noting changed
    Hello Al....I loaded a BC4axis mil but , as You can see on the attached file , noting changed! Where I'm wrong please.
    Mar 2012
    1570
    I am in the office right now, if you can let's connect computers and get this sorted...
    Al DePoalo
    Jan 2011
    73
    Thanks Al for your help !!!!!! You were so kind!!!!
  1. Replies: 8
    Last Post: 07-26-2013, 01:24 AM
  2. Wrapping Text Around a Cylinder
    By aus10eww in forum BobCad-Cam
    Last Post: 04-12-2012, 08:41 PM
  3. Wrapping text to a radius?
    By MMT in forum BobCad-Cam
    Last Post: 12-05-2011, 09:33 PM
  4. text wrapping question
    By h_2_o in forum Uncategorised CAD Discussion
    Last Post: 04-07-2009, 08:59 PM
  5. wrapping around cylinder
    By Craigpat in forum Solidworks
    Last Post: 05-21-2008, 03:45 PM
