585,982 active members*
4,563 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > post processor for mach 3?
Results 1 to 16 of 16
    Jan 2006
    9
    I have seen it and i want to use it. Does anyone have a ready post processor for Mach 2/3 so i can do code for my machine? I dont know how i shall use the wizard and what template i shall base it on.
    Dec 2005
    Any success with this? I use edgecam code in mach3 now with some manual editing but it would be nice to generate Mach3 code directly.
    any hints are welcome
    kind regs
    Mar 2006
    1013
    Can you send up some code examples? I dont know anything about the Mach2/3. If it's G-Code you should be able to use the Wizard to get it right pretty quickly.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Sep 2005
    197
    Hi I have this. It's a post for Mach2 and I think I will work with mach3 also. I wrote this one to a friend so I belive It is some bugs there maybe. But in the you have all the files so you can modify the post your self. I take no responsibility for problems regarding this post. Unzip the file and copy the files to the c:/programfiles/edgecam/machdef folder.
    If anyone have edgecam post for deckel I in very interested.
    Attached Files Attached Files
    Dec 2005
    Works fine with mach3 ( with the stuff i tested so far...) Tnx alot.
    kind regs
    Sep 2005
    197
    I think there could be a bug that can give a strange z move in the beginning. Or maybe I have fixed that. If you find any problems tell me and I can try to fix it.
    Mar 2008
    11
    i have tried this file with Edgecam...and i am getting this error msg:
    "R i j k words all missing for arcLine 116"
    in mach3
    what seems to be the problem?...can any1 help me?
    Sep 2005
    197
    If you could upload the edgecam file the NC code and maybe you know wich line it stopped at. Then I can fiks this I belie. I made the post for Mach2 so I belive I can modify this.
    I belive that this is a bug with arcs. But probably it only appears somethimes. Because this is not a message you get always or what?
    Mar 2008
    11
    Thanks for your quick reply...
    I think i did something wrong with the original files...(dont know what)...
    but, then, i recopied your files from the zip file and then did it again and it was working just fine...
    i am really sorry for this....
    Thanks again for you help.
    Dec 2005
    16
    ali97 or anybody
    Hello, !! I am looking for a post for cutting arcs on my lathe for Mach3. I just want to cut simple things to start. I am learning mach3 and not very good at g coding.
    Cn anybody help?
    mungaro
    Aug 2006
    12
    Have you resolved this issue? I'm having the same problem
    thanks
    Jul 2005
    20
    Anyone managed to make it work?
    I have a homemade cnc milling machine.
    I am looking for a way to generate gcode from Edgecam to mach3,
    Does anyone managed to do so?
    Thanks you!
    Oct 2003
    155
    Mach .cgd attached
    Attached is a file that I use with Mach 3 & Edgcam 2010 R2 on my 3 axis table top Shark router.
    As with any post use this at your own risk.
    Put this in your machdef folder and compile with code wizard.
    MM
    Dec 2008
    441
    Re: post processor for mach 3?
    Is there a updatet post for Edgecam here? I also get the same problem with IJK i arc movements...
    Thanks.
    -Robert
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Apr 2014
    Does anyone have postprocessor for mach3 for 4th axis?
    Jul 2017
    348
    for whatever reason the file wont open in code wizard
    does anyoje have a valid post processor for mach3 for edgecam?
  1. Mach 3 Post Processor goes where????
    By USMCCNC in forum G-Code Programing
    Last Post: 06-15-2010, 06:17 PM
  2. Post Processor for Mach 3????
    By basskitcase in forum Rhinocam
    Last Post: 02-16-2010, 11:28 PM
  3. Mach 2 Mach 3 Post Processor
    By IntarisiaQ4 in forum Australia, New Zealand Club House
    Last Post: 10-17-2009, 11:50 PM
  4. re post processor v21 mach 3
    By woffler in forum BobCad-Cam
    Last Post: 06-06-2008, 03:49 AM
  5. VM 3.0 Post Processor for Mach 3 OR 2
    By TCSpooner in forum Visual Mill
    Last Post: 12-28-2007, 03:55 AM
