Originally Posted by
Beezle
Maybe not the best forum for this question, but since this is the machine I use, I'm asking here. PCNC 1100 here. TTS tooling.
So I decided to try try to work out using Vectric's V-Carve toolpaths in aluminum. I have seen the work of the Air Force guy on Vectric's forum. Looks great, but he uses a big Fadel.
I have tried quite a few chamfer mills, mill-drills, etc. from Niagara, Lakeshore Carbide, Ultra-Tool and 2L. All pretty much the same though the 2Ls are nice in that you can get a very fine (.005") tip. All are either 3/8 or 1/2" in diameter. I go for the least stick out in an ER20 holder.
60 and 90 degrees, convention and climb cutting, really slow feeds, faster feeds, spindle at 5100. Fog Buster and flood coolant. Cuts are .05 to .08 deep, with cut depths attempted from about .015 to about .030.
And I have yet to come up with decent results. With for example decent carbide end mills (Niagara and Lakeshore Carbide) I get very nice cuts, but sometimes I need the definition that a V cutter can provide. Sharp inside corners.
What I see is chatter, horrible burrs, etc. Given this is 6061 that's not a big surprise, but I keep thinking someone must make a chamfer mil that isn't plain straight flutes? Lakeshore makes a nice spiral one, but the tip is too big and I would guess it cannot be plunged.
Any thoughts on improving this appreciated.
Make the line you're chamfering .050 inside the line you want to chamfer, use the center of your tool, slow your spindle down to 3500 RPM and feed it 20 t0 25 IPM. I do this all the time and my parts come out beautiful, with no burrs.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
