585,987 active members*
4,468 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Drive constantly "Recovering from follow error or from disabled state"
    Nov 2012
    18
    Really as per the title, I have some motors hooked up to a VSD-E in dual DC mode, however I'm having trouble with them because the drive is constantly entering fault mode and then slowly moves to position. I have set the following error at a generous 8096 counts, which should equal a full turn of the shaft (2048 cpr encoder with quadrature decoding). The motors seem to be well tuned with maximum encoder counts in the 20-30 range when using DC tool.
    The current given to the motors also seems to be a bit low, is it necessary to setup drive in GDtool before using DCtool? I've set it to the highest values I can in DC tool but I don't think it's using them.
    Jan 2011
    25
    It sounds like there may be a parameter not initialized. I would run GDTOOL first.
  1. "master encoder state error" AB ultra100 error message
    By ShapeShaver in forum Servo Motors / Drives
    Last Post: 07-31-2013, 04:09 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Pregunta "machine state display"
    By rposadap in forum Spanish
    Last Post: 09-07-2009, 04:51 PM
  4. Disabled "Lathe Index" command
    By vadim_m in forum EdgeCam
    Last Post: 02-19-2009, 12:23 PM
  5. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
