586,024 active members*
4,026 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > NEED HELP WITH Lantek Expert Com program
    Nov 2013
    Hello!
    I have a problem with Lantek program...When is generated the CNC program, the line which definde the sheet thickness (#101=1.0, for exemple) is missing, soo I have to introduce this line by hand...This is mean that, I have to modify all CNC program for every punch program.It's not ok, because the CNC programs are too long and it's take time to modify....
    Does everybody know if this can be fixed...It is an option to apply to generate this line automatically? Or was the install problem?
    Thank You!
    Apr 2010
    22
    Hi. Did you found a solution ? If not PM to me and i can see what i can do
    Apr 2010
    22
    Hi. Did you found a solution ? If not PM to me and i can see if i can help you out
    Oct 2014
    9
    Re: NEED HELP WITH Lantek Expert Com program
    hello.
    have anyone experience this problem or can help with a solution
    http://www.cnczone.com/forums/genera...ml#post1582290
  1. lantek expert 1
    By boomer187um in forum CamSoft Products
    Last Post: 01-13-2024, 09:26 AM
  2. i'm looking for lantek expert v 27
    By agiorgos in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 08-22-2023, 11:33 AM
  3. lantek expert use
    Last Post: 05-30-2020, 08:56 AM
  4. Problem when Lantek generate the program
    By ClicK10 in forum Uncategorised CAM Discussion
    Last Post: 03-07-2014, 05:28 AM
  5. Lantek Expert
    By one5 in forum Laser Control Software
    Last Post: 04-20-2013, 07:29 AM
