585,926 active members*
3,781 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Solidworks -> Cam Software -> Mach3
Results 1 to 9 of 9
    Jan 2012
    394
    Okay, I understand I need to go from my Solidworks software, to a cam software, to Mach3.
    But, which Cam software is the best to work with Solidworks, yet, cheap? Cheap, as in under $500
    I will be using 3 axis with a 4th axis added later in the future.
    I was thinking Artcam Express, but it doesn't seem to do 4th axis?
    Any help is appreciated, thank you.
    Dec 2003
    673
    I don't think "best", "Cheap" and "4th axis" come anywhere near each other... I used to use various cheap CAM, then hand edit the code for anything the software doesn't do - especially 4th axis...
    35538
    Do you want something to work with 3D models. If so, do you want it to read solidworks files or step or iges? Those will most likely be over your budget.
    ArtCAM Express is more of an all in one design/CAM package, and would probably only import 2D .dxf files or .stl files. However, for a lot of router work, 2D CAM is usually much faster and more efficient.
    What exactly do you plan on making? Different CAM packages work much better for some things than others.
    Deskproto's Hobby license is probably the cheapest 4th axis software out there. There's also MeshCAM, but it only does indexed 4th axis.
    Oct 2012
    29
    One more option is HSMXpress, do keep in mind it only does 2D operations, but I believe does support a 4th-axis.
    Feb 2009
    311
    HSMXpress is great but does not support 4th axis. For that you would need the full HSMWorks, which is not even close to $500.
    C|
    Oct 2012
    29
    Quote Originally Posted by cygnus x-1 View Post
    C|
    Thought it supported the indexing, but too bad then!
    Sent from my C5503 using Tapatalk
    Feb 2009
    311
    Quote Originally Posted by laurensschu View Post
    To be honest I've never actually looked for it. But I've been using HSMXpress for almost 2 years and I've never seen anything that indicates it might do 4-axis indexing. It would be cool if it did though.
    C|
    You can do 4th Axis by having a new WCS for each orientation.
    Bit, CYGNUS is correct. for proper 4th Axis you would need HSMWorks
    Oct 2012
    29
    Yes we do understand, you would a least need HSMWorks to do 4 axis simultaneous. But most people only use indexing anyway.
  1. I have Haas and Solidworks and need CAM Software
    By bmwjoe in forum Uncategorised CAM Discussion
    Last Post: 03-01-2012, 02:19 PM
  2. Solidworks + Mach3
    By Simon Wells in forum Mach Wizards, Macros, & Addons
    Last Post: 07-13-2011, 04:43 PM
  3. Solidworks to Mach3
    By spaltiel in forum DIY CNC Router Table Machines
    Last Post: 04-03-2010, 11:25 PM
  4. Replies: 0
    Last Post: 07-16-2009, 12:43 AM
  5. FEA software for Solidworks
    By georgebarr in forum Solidworks
    Last Post: 01-17-2006, 04:33 PM
