Hello
This is first post. I have an oppurtunity to get a 1997 Cadet Mate with OSP700M control. I have a couple questions
How reliable are these machines? Are they still supported?
Is the OSP700 easy to program at the control?
Right now machine as couple issue's.
Door interlock has been fiddled with and keeps causing alarm so has to be reset each time. Present owner put a switch in to reset. I would like to either eliminate it or at least be able to run with door open for proofing.
Also get an alarm for "Z" axis lube timed out.
Rob
