How to change cutting speed of SteelTailor portable CNC cutting machine?
(1)First set the maximum cutting speed in SETUP [F4]----SPEED[F1]----MACHINING SPEED set the value is mm/min in metric mode or inch/min in inch mode.
(2)The value set in the SteelTailor CNC cutting MACHINING SPEED is the maximum speed at which the machine will move while cutting .
(3)In AUTO mode the cutting speed can be adjusted while cutting operation by pressing
Attachment 209572
User can increase speed to a maximum value set in SETUP[F4]----SPEED[F1]----MACHINING SPEED
(4)In AUTO mode before the cutting operation or while the cutting is paused a desired cutting speed can be entered by pressing F key on the SteelTailor controller. You can enter the desired cutting speed (Value should be set between 05 ~ MACHINING SPEED) after entering the value Press ENTER key.
FAQ - Parts&Service - SteelTailor offers portable CNC cutting machines,portable table plasma cutting machine,CNC plasma and flame cutting machine,cnc plasma cutters
