585,604 active members*
3,420 visitors online*
Thread: mac turn 550
    Nov 2013
    mac turn 550
    Hey i have a problem regarding alarm 1812 mist lubrication unit 2.
    I am 2 weeks into a new job and this is my first time working with okumas. Im getting the hang of the machine but this alarm now keeps on re occuring the second i start my cycle. The oil mist unit is full at the front next to the lube oil. Is there another unit on the machine i should be looking for? also when the machine is running the oil unit is only getting to 0.05 bar of pressure which seeems awfully low? Anyway to crank this up to 0.1 bar i think it should be running at?
    Working pressure when machine is running is sitting just below 0.2mpa and mnifold pressure is sitting at 0.05mpa
    working pressure should be at 0.22mpa and manifold should be at 0.1mpa
    Any help would be great
    thanks
    Nov 2013
    right i turned up the working pressure and the manifold pressure is now just sitting below 0.1mpa.
    I got the machine going again for about 30 mins then the same alarm came up.
    in my lube parameters i have
    lube motor on timer = 60 seconds
    lube motor off timer = 4 mins
    lube motor off timer count during axis move = ticked box
    number lub motor on at power on = 3 times
    turret index time = 1 second
    lub motor max off timer = 1 hour
    oil mist lub drip frequency = 2 times
    lub motor on timer xs axis = 15 seconds
    lub motor off timer xs axis = 1 min
    lub motor off time count during cam axis mode = box unticked
    Any able to check there machine see if any of these on/off times are interfering with 1 another causing the machine to alarm out
    Aug 2011
    2517
    the parameters look ok. probably the filters in the line or at the manifold are blocked it's a pretty common problem. you need to remove and clean or replace them.
  1. MachStdMill Turn and Mill-Turn Announcement
    By mvcalypso in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-16-2012, 03:38 PM
  2. Announcement: MachStdMill Turn and Mill-Turn
    By mvcalypso in forum News Announcements
    Last Post: 04-12-2012, 07:59 PM
  3. mill/turn on a cin turn
    By Robert Timby in forum Uncategorised MetalWorking Machines
    Last Post: 02-01-2007, 05:33 AM
  4. Cin Turn turn/mill
    By Robert Timby in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2007, 02:12 AM
