585,902 active members*
4,331 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Need Help to pass Solidworks cutting profile to Mach3
    Feb 2011
    9
    Hi Guys
    I build some time ago a 4 axis hotwire cutter with which I cut several wings under Mach3 and with the cutting path coming from a specialised software.
    Finally the time has come to cut my fuselage plug in styrofoam. I have designed the beast in solidworks and want to cut in 130x2 2 inch slices.
    as you can see from the attachments I will create 130 3D Drafts and want the hotwire to follow the perimeter. While doing the the first intersection thru the body i notice the the line is not continous and where disjunct i cannot add any relation to match the end of the line segments. However how can i proceed to be able to digest these drafts and therefor cutting paths in mach3? I am completely lost on how to move on from here. Basically passing from a dxf to g-code
    Thanks everybody for your help.
    Jun 2008
    562
    First off , get rid of the thin offending area generating the overlap of lines.
    I would use the "split" command. You can put down 130 lines on a plane and split the part into 130 pieces. You can also cut the part with a single line and save off each piece(but you have to do it 130 times). See HELP menu. There are several different ways to do this, then export to the needed format.
    Mike
  1. How to pass strings from kflop to mach3?
    By flegrand80 in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-08-2013, 06:06 PM
  2. Cut 2D Profile pass
    By laserpilot in forum Vectric
    Last Post: 08-07-2012, 04:41 AM
  3. mach3 and the vcarve? the pass after
    By topline in forum Mach Mill
    Last Post: 06-12-2012, 12:08 AM
  4. Cant profile solidworks guitar?
    By Momentz in forum Rhinocam
    Last Post: 04-11-2012, 12:46 AM
  5. G71 rough boring - remove final profile pass
    By Busted in forum G-Code Programing
    Last Post: 01-19-2009, 07:08 PM
