The cut angle of SteelTailor portable CNC cutting machine is too big, why?
Attachment 210414
To determine whether a cut-angle problem is being caused by the plasma system or the drive system,pls make a test cut and measu re the angle of each side. Next, rotate the torch 90° in its holder and repeat the process. If the angles are the same in both tests, the problem is in the drive system.
If a cut-angle problem persists after “mechanical causes� �� have been eliminated (see the previous page, En sure the torch and table are set up correctly), check the torch-to-work distance, especially if the cut angles are al l positive or all negative. Also consider the mate rial being cut: if the metal is magnetized or hard ened, you are more likely to experience cut angle problems.
The squarest cut angle will be on the right side w ith respect to the forward motion of the torch. Th e left side will always have some degree of be vel.
Thank you
If you have any question about portable CNC cutting machine. SteelTailor will be very glad to help.
SteelTailor--The world leader of portable CNC cutting machine
www.steeltailor.com
