585,974 active members*
4,219 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Sacrificial table: MDF 18mm vs Hardwood 3.2mm vs stainless steel 3mm.
    Sep 2013
    13
    Question Sacrificial table: MDF 18mm vs Hardwood 3.2mm vs stainless steel 3mm.
    Looking for best sacrificial table.
    Milling aluminium (6082T6), stainless steel (316) and some wood.
    Is MDF appropriate for milling steel and aluminium ??? (bottom table is T-table)
    Now I wonder how will I fix clamping as I used t-nuts and it worked really well, thing is that if I will add some sacrificial table I will use ability to use t-nuts...
    What is your way to use sacrificial table and what clamping are you using ?
    Apr 2009
    5516
    I would hardly call stainless steel sacrificial material... Plus the thickness you specify for the hardwood and stainless might be difficult to keep flat. MDF is great but I don't know how well it would last when sparks fly from the stainless, and if you use coolant the MDF will swell and expand. You might want to consider getting a sheet of paper-based phenolic for your spoilboard...
    Sep 2013
    13
    I start thinking about using some pre-cut MDF boards (as my CNC mostly is milling 10-12 models, and only sometimes I'm cutting something for myself).
    Jan 2008
    940
    You could use extira MDF it is supposed to be water proof.
    Aug 2011
    999
    Given that the stainless steel is very tough to machine methinks a proper machine vise with flood coolant is the answer. Now, the aluminum could be milled dry or with minimal cooling and clamping to a table will work if thick enough.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
  1. 303 vs. 304 stainless steel
    By pearldiver in forum MetalWork Discussion
    Last Post: 02-06-2020, 08:45 AM
  2. need sacrificial material to work with vacuum table
    By hazelelectronic in forum Want To Buy...Need help!
    Last Post: 10-04-2013, 05:49 PM
  3. Stainless or non stainless steel ACME screws?
    By amanmazleigh in forum Linear and Rotary Motion
    Last Post: 07-07-2011, 05:00 AM
  4. Baseboard/vacuum table...are they sacrificial?
    By Matty Zee in forum DIY CNC Router Table Machines
    Last Post: 03-12-2007, 10:57 PM
  5. Stainless Steel ?
    By Depoman in forum MetalWork Discussion
    Last Post: 01-12-2005, 12:40 PM
