Can anyone tell me if I can monitor external signals with the Macros? I want to check for the fixture clamping signal this way instead of the firing the M code for it every tool change. This takes time that we don't have to spare. This hydraulic clamping set-up is a factory installed interface for an external hydraulic tank and pressure switches. I just wan to check and see if the clamping pressure switch is made with a cnc macro in the cnc program if I can.
Any help with this will be appreciated. Thanks.
